need help: new xml files for upcoming ECUFlash release
Old Feb 3, 2009 | 11:26 AM
  #211
gsrboi80's Avatar
Originally Posted by mrfred
If you want, yes. The advantage of the separate file is that its easier in the long run... Just move the mods file over each time a new update is released.
Now I get it. Yea that does make sense. Thanks man
Old Feb 13, 2009 | 10:35 AM
  #212
fostytou's Avatar
EvoM Community Team
https://www.evolutionm.net/forums/6688770-post841.html
This may be pertinant. Not sure if Mr Freds defs were used in the most recent version of 1.41.
Also, wouldn't it be nice if the mods file could <exclude> a table from the other XML? EG: to get rid of the maps replaced by tephra's altmaps.
EDIT: Fixed, nevermind.
Old Feb 13, 2009 | 11:03 AM
  #213
fostytou's Avatar
EvoM Community Team
Does anyone know if there is a flag or an option we can set to make the default status of all of the sections "collapsed" instead of expanded? It seems like every time I open ECUFlash I collapse all of the sections by hand and then expand only the ones I'm working with.
Old Feb 28, 2009 | 01:24 AM
  #214
al\lupo's Avatar
There is a mismatch in evo9base: the MAFHz frexpr is wrong, here is the correct one:
Code:
<scaling name="MAFHz" units="Hz" toexpr="6.29*x/64" frexpr="64*x/6.29" format="%.0f" min="0" max="5000" inc="1" storagetype="int16" endian="big"/>
Old Mar 22, 2009 | 11:44 AM
  #215
raasfaas's Avatar
Bringing back this thread...need a little help here
I just installed ecuflash v1.41 and followed the instructions to do the XXXXXXXX_mods.xml file. Pretty much the only patches I have are Tephra's V5.10, and JDM Map sensor patches...since the 1.41 already comes with the mut tables, lean spool tables and 2 byte stuff I just took them out.
I'm coming from 1.29a so I know I had to change the endian to big in the tephra mods. I'm pretty sure I did everything ok, but when I open my .hex in 1.41 only the tephra stuff from my _mods file show up properly, the map sensor stuff are grayed out. Yes I am in developer mode. Although they're grayed out I can still open the tables and view and change what's in there.
Any idea whats going on here?
File Type: txt
Old Mar 22, 2009 | 08:47 PM
  #216
mrfred's Avatar
v1.41 pays more attention to the level value in the definitions. Try changing the level="1" to level="2" or just delete the level modifier.
Old Mar 22, 2009 | 09:40 PM
  #217
raasfaas's Avatar
Thanks mrfred changing it to level 2 worked
One more thing, do you know if the tactrix 1.3 cable is compatible with 1.41? Haven't had a chance to check it yet.
Old Mar 22, 2009 | 10:31 PM
  #218
mrfred's Avatar
Most of the older cables work work with v1.41. There is only a small batch of the older cable that do not work.
Old Mar 23, 2009 | 01:59 PM
  #219
raasfaas's Avatar
Well just my luck, I happen to fall into that small batch of older cables that don't work. It says that it cannot connect with the interface. Is there some update that I need to do or once it isn't able to connect that's it?
Old Mar 24, 2009 | 03:32 PM
  #220
raasfaas's Avatar
Is there a software update that is needed for the tactrix 1.3 cable to work with ecuflash 1.41?
Old Mar 24, 2009 | 03:47 PM
  #221
mrfred's Avatar
If you bought the cable from Tactrix and still have the receipt, give them a *call*. If you bought the cable from Limitless (EvoScan), contact them. They can help you get your cable working with the latest versions of ECUFlash.
Old Mar 25, 2009 | 09:12 AM
  #222
fostytou's Avatar
EvoM Community Team
Code:
It shouldn't matter thanks to order of operations, but you may want to keep the parens just for accuracy (and yes, it was incorrect in my 1.41 also):
Code:
<scaling name="MAFHz" units="Hz" toexpr="6.29*x/64" frexpr="(64*x)/6.29" format="%.0f" min="0" max="5000" inc="1" storagetype="int16" endian="big"/>
This increment update also helps a ton with being able to incriment the injector latency:
Code:
<scaling name="InjectorLatency" units="ms" toexpr="x*0.024" frexpr="x/0.024" format="%.3f" min="0" max="4" inc="0.024" storagetype="uint8" endian="big"/>
Old Mar 26, 2009 | 07:40 AM
  #223
japanevo's Avatar
if it isn't to late to make a contribution i have a 9055 rom i can send you.... however. i tried it with the evo7base in the zip file on this thread and cant view half of my tables. so if you can give me a couple of days to get everything working again that would be great.
Old Mar 26, 2009 | 10:06 PM
  #224
japanevo's Avatar
looked at both evo7bases and all of your definitions are almost the same as mine just minor changes i made to mine to get them working. also i have a lot of tables in my 7base that you didnt have. i made a txt with the changes for you to look at i also included the tables that i use along with my 9055 xml. carfull i have just about all of the mods i can think of in my 9055, tephra and SD.
File Type: zip
Old Mar 27, 2009 | 07:42 AM
  #225
logic's Avatar
mrfred, do you think it would be possible to get the MUT table definition in evo7base_*.xml changed to this one (with the "RamAddress" scaling)? The default version is almost unusable for some of us using small form-factor systems for flashing (tablets, netbooks, etc; the maximum resolution on my tablet is 800x600).
Code:
	<scaling name="RamAddress" units="hex" toexpr="x-4294901760" frexpr="x+4294901760" format="%04X" min="0" max="65535" inc="1" storagetype="uint32" endian="big"/>
	<table name="MUT Table" category="Misc" type="3D" level="1" scaling="RamAddress">
		<table name="X" type="Static X Axis" elements="16">
			<data>0</data>
			<data>1</data>
			<data>2</data>
			<data>3</data>
			<data>4</data>
			<data>5</data>
			<data>6</data>
			<data>7</data>
			<data>8</data>
			<data>9</data>
			<data>A</data>
			<data>B</data>
			<data>C</data>
			<data>D</data>
			<data>E</data>
			<data>F</data>
		</table>
		<table name="Y" type="Static Y Axis" elements="16">
			<data>MUT0X</data>
			<data>MUT1X</data>
			<data>MUT2X</data>
			<data>MUT3X</data>
			<data>MUT4X</data>
			<data>MUT5X</data>
			<data>MUT6X</data>
			<data>MUT7X</data>
			<data>MUT8X</data>
			<data>MUT9X</data>
			<data>MUTAX</data>
			<data>MUTBX</data>
			<data>MUTCX</data>
			<data>MUTDX</data>
			<data>MUTEX</data>
			<data>MUTFX</data>
			<data>MUT10X</data>
			<data>MUT11X</data>
			<data>MUT12X</data>
			<data>MUT13X</data>
			<data>MUT14X</data>
			<data>MUT15X</data>
			<data>MUT16X</data>
			<data>MUT17X</data>
			<data>MUT18X</data>
			<data>MUT19X</data>
			<data>MUT1AX</data>
			<data>MUT1BX</data>
			<data>MUT1CX</data>
			<data>MUT1DX</data>
		</table>
	</table>
