Tephra, can you make a mod to fix the VIII's p0300 issue?
Old Apr 10, 2008 | 03:58 PM
  #46
spdracr's Avatar
between this and the phantom knock when pulling from a stop is driving me nuts lol
Old Apr 13, 2008 | 08:42 AM
  #47
tkklemann's Avatar
Bump, I am just now starting to get a rash of these, about every third time I drive the car. I bought a cel reader just to keep turning it off now. Mine has a lightened Fidanza flywheel too, and it rattles like a bucket of bolts in the pressure plate. I know it was installed right because I did it, and I am one big **** orfice when installing stuff. I triple checked everything, even maked off all bolts with a paint marker after torquing them..
No other codes are being thrown except the P0300. FYI, I am on the 96940011 Rom..
Old Apr 13, 2008 | 10:35 AM
  #48
Markley02's Avatar
Originally Posted by mixmastermatt
I think the thing to get from the tech description is the harmonic imbalances. A lightened flywheel could definitely create an imbalance that could be detected and considered "misfire" by the ECU. Also, the range of crank angle acceleration detection could be different in early ECU roms, i.e. they could be more sensitive. I don't know if any of the disassemblers have come across the routine for it or not, but if they find it, I'm sure the "sensitivity" could be adjusted until the code stopped coming up.
Just to back up his theory... In a e36 BMW (M3 325 328) if you do a lightened flywheel and lightened crank pulley say bye bye to your crank. Either one by itself is fine. Do both and it throws off the harmonic balance of the crank.
Old Apr 13, 2008 | 11:52 AM
  #49
draconx's Avatar
yup yup
Old Apr 15, 2008 | 03:30 AM
  #50
tkklemann's Avatar
Damit, now it's lighting up every third time I start/drive the car. I am going to check into a few other parts first, before I say it isn't a mechanical problem. I think i am going to do all the routine maintenance and see if it lessens in frequency..
Old Apr 15, 2008 | 11:30 AM
  #51
M3rcer's Avatar
I'm there with you guys, fidanza flywheel and stage 3 clutch. CEL's ever since, gotta keep it off for my NY inspection and then I could care less about it. Btw, how much is a CEL reader/reset tool?
Old Jun 8, 2008 | 12:59 PM
  #52
GTR2009's Avatar
I have the same problem with the random missfire error on USDM evo 8, it appears only when cruising at no load, between 3800-4500rpm, I have a transmission noise, because the gearbox has some problems... I don't know how to get rid of this error.
Old Jun 8, 2008 | 01:03 PM
  #53
Jack_of_Trades's Avatar
No one knows how to 100% fix this problem yet. Some have found the CEL parameters in the ROM and are working on a way to trick the ECU into ignoring CEL P0300 but its not ready yet. Nothing you do will 100% fix this problem so don't waste hours of time trying to eliminate it. You might make it happen less frequently, but it will still come back. Some cars have no issues with it and some are plagued with it constantly.
Old Jun 8, 2008 | 01:11 PM
  #54
ApacheFixer's Avatar
i started seeing the p0300 code after i had my cams installed. Im still on stock clutch/flywheel and it lights up about once a week.
Old Jun 8, 2008 | 05:12 PM
  #55
GTR2009's Avatar
thanks !
on my customer's EVO 8 the clutch is ralliart, a competition clutch which is very hard to drive on street at low speed. Also the gearbox is almost gone.
Old Jun 8, 2008 | 05:24 PM
  #56
EvoDan2004's Avatar
i hope there is a fix for this. im on the 0008 rom and i get this all the damn time. it will not go away. it also stops me from passing inspection. did anyone ever figure out a fix/override for the p0300 yet?? or are they working on it?
Old Jun 9, 2008 | 09:48 AM
  #57
gsrboi80's Avatar
I fixed mine. I never got the code at cruise just during idleing situations. I updated to the 15 ROM. Still got the code at idleing situations.
I finally fixed it by just pulling some timing out of the idle portions of my map. I have not had the dode now in about 6k miles
Old Jul 29, 2008 | 01:34 PM
  #58
mfr122887's Avatar
Any news on this?
Old Jul 29, 2008 | 05:46 PM
  #59
Slo_crx1's Avatar
Guys with 8's, I'm tellin' ya...drop the egr timing (incorrectly labeled as boost enhancement adv/ret 2) by about half and usually it goes away, especially if you have cams. I've done this with 2 evo 8's now including my own and neither one of us has had a p0300 issue in over a month.
Old Jul 29, 2008 | 05:58 PM
  #60
mfr122887's Avatar
So you cut each value in half? And just to make sure I have the right definition, in table 1 they are all 0's right?
