Tephra, can you make a mod to fix the VIII's p0300 issue?
Subscribe
Mar 29, 2008 | 05:06 PM
Or any other Guru's of course
Can you make a mod to fix the VIII's p0300 issue? This is the one that some users have to use the C-reader to get rid of that is probbably caused by some type of vibration. Like in enginuity / rom raider where you can just permanently turn off a code.
Reply 0
Mar 29, 2008 | 06:03 PM
whats p0300 for? misfire or something?
trouble with evo's is we don't know very much about how the DTC codes work (in the code that is)
ill have a look for it after ive done with V5
Reply 0
Mar 29, 2008 | 06:13 PM
po401 here. i have to keep my creader plug all the time
Reply 0
Mar 29, 2008 | 06:19 PM
Quote: po401 here. i have to keep my creader plug all the time
just disable it...that's an easy fix.
Reply 0
Mar 29, 2008 | 08:22 PM
Mr. Evo IX what ecu ID do you have?
Reply 0
Mar 30, 2008 | 01:20 AM
tephra. its a random mis-fire. its caused by lighten flywheels (thats why i've come to believe). its really annoying too. if you could make a patch to disable the code all together or somethin that would automaticaly clear it that would be AWESOME . its really annoying have to have my laptop out everytime i go for a long drive cause that stupid thing comes on.
Reply 0
Mar 30, 2008 | 05:34 AM
Is it a perf affecting CEL? ie does the car run differently when its ON?
Reply 0
Mar 30, 2008 | 05:37 AM
its not performance effecting.
Reply 0
Mar 30, 2008 | 12:01 PM
yea the car will misfire and vibrate. its really annoying. i just bought a creader that will automatically erase it but it would be awesome to get one with a patch so i dont need to use it .
Reply 0
Mar 30, 2008 | 03:35 PM
so the misfire is real?
what romid u guys using?
Reply 0
Mar 30, 2008 | 04:12 PM
Make sure the egr valve hasn't become unattached to the vacuum line. Its a common issue. I've fixed 4 of them on evos here in Houston this month and that was the issue. The line just comes off sometimes.
Reply 0
Mar 30, 2008 | 08:07 PM
pretty sure it is. im currently using 0015. was using 0008 but changed cuase of the new v5 mods you released
Reply 0
Mar 30, 2008 | 08:21 PM
and you still get P0300 with x15?
Reply 0
Mar 30, 2008 | 08:28 PM
Has anyone else noticed that when the periphery 2 is set to 0x8D89 the rate of P0300 seems to drop? I havent ever had a misfire code in my car in nearly 29k even with all the different mods that I have. However one of my friends with an almost stock MR had P0300 as soon as I flashed the car, that would go away when it went back to a stock map. He sold it before I even thought that there might be a connection. He lived in an emissions area so I didnt turn any of that stuff off on his car.
Worth a try for those that have chronic problems maybe.
Reply 0
Mar 30, 2008 | 08:31 PM
Quote: Has anyone else noticed that when the periphery 2 is set to 0x8D89 the rate of P0300 seems to drop? I havent ever had a misfire code in my car in nearly 29k even with all the different mods that I have. However one of my friends with an almost stock MR had P0300 as soon as I flashed the car, that would go away when it went back to a stock map. He sold it before I even thought that there might be a connection. He lived in an emissions area so I didnt turn any of that stuff off on his car.
i havnt changed any of those periphery's.
Reply 0
