ECU Question
Old Apr 2, 2008 | 07:25 AM
tseitz123's Avatar
ECU Question
OK, so here is my situation:
I am in the process of basically swapping an 05 evo into the shell of an 03. It doesnt matter why. The shell has its ignition, key, immobilizer, and ECU, as well as its dash and engine wiring harnesses. Now, I want to use the 05 ECU in the new 03 evo. How do I go about doing this? If I just swap in the 05 immobilizer and ECU, obviously the car won't start unless I can get into the ECU and disable the immobilizer, correct? If I try to use ECUflash with the 03 key/ignition and the 05 immobilizer and ECU installed, can I at least access the ECU in order to make the changes I need to (i.e. disable the immobilizer)? Please help
Old Apr 2, 2008 | 05:57 PM
tseitz123's Avatar
Bump!
Old Apr 3, 2008 | 07:22 AM
tseitz123's Avatar
No one knows the answer to this?
Old Apr 3, 2008 | 07:33 AM
jmelocik's Avatar
Hey Bro. Maybe try pming Tephra or John Bradley as they are masters of dissecting the ECU. Hope this helps
Josh
Old Apr 3, 2008 | 11:50 AM
roger smith's Avatar
If I understood everything correctly then you should get the immobilizer code from the 03's ECU and then swap in your 05 ECU and put the code from the 03 into your 05 ECU.
Old Apr 3, 2008 | 01:58 PM
mrfred's Avatar
If you're installing an entire '05 Evo 8 drivetrain into an '03 Evo 8, the biggest problem I see is that there will be no wiring to control the ACD unit. And there is an ACD ECU that will need to be installed. Also, the ECU does either send or receive information (I forget at the moment), so you'd need to get that wiring working as well.
Old Apr 3, 2008 | 08:26 PM
tseitz123's Avatar
The whole ACD system has been removed. You know what? It doesnt matter. I will just use the 03's ECU and Immobilizer and just copy over my maps, etc.
Old Apr 4, 2008 | 11:49 AM
cssaddictm4's Avatar
Or you could connect with ECU flash and write down the code and then swap the ECU and the connect and write the ignition key code into the 05 ECU.
Total time=10minutes
ScubaStevo
Oct 13, 2016 02:36 PM
Dnasario
Jan 16, 2016 08:52 AM
mikgsxx
Feb 1, 2015 06:44 AM
secretagentstv
Oct 5, 2014 12:13 PM
EVOMIZ
Nov 27, 2011 05:33 PM
