Looking for input on my logs
Old Apr 3, 2008 | 02:07 PM
93 3gt vr4's Avatar
I did a few pulls the other night wondering what people thought of my logs. I need some input on how the fuel is looking. THanks
File Type: txt
Old Apr 3, 2008 | 02:15 PM
kreionic's Avatar
why do you have A/f dip into the high 10s from 4200-to 4600? Timing is very tame just about everywhere and I would hold that 11.6 a/f till redline but thats me. Some like to taper by redline but your still to rich from 5k up. Its a good starting point though
Old Apr 3, 2008 | 02:22 PM
93 3gt vr4's Avatar
timing is how conservative? other than the upper end being rich, the rest looks fine?
Old Apr 3, 2008 | 02:27 PM
JohnBradley's Avatar
What are the mods and how much boost? Is the load figure that you have 2 byte or calculated? Fueling should try to be fairly consistent to keep torque even across the board and keep power up as well.
Generally 11.5-11.7 is safe at high boost on pump.
Stock turbo can be safely run at 25-26psi on 92-93 with the timing you are running.
Oh and your lean spool is still on. I can see it right at 7150 go REALLY rich.
Old Apr 3, 2008 | 02:43 PM
ChuckP's Avatar
What year evo?
93 3gt vr4's Avatar
ur good. Lean spool is on (haven't seen any pros/cons to it), open air filter, 880s walbro, dp, catfree,mbc. Im running 93oct. Its set to 25psi. I do have 2byte load flashed. Thats the load value in the logs. 06 mr. What would agressive timing look like?
Old Apr 3, 2008 | 05:30 PM
Rare5spd's Avatar
What up jig!! I agree with kreionic. Lean it out a little to 11.6 and add some timing.
If you want to view the log in excel, just change the extention to .xls when you save it to your computer.
+free bump
Old Apr 3, 2008 | 05:40 PM
93 3gt vr4's Avatar
what up! First post huh. lol. Thats what i was figuring. I'm also curious how conservative my timing is. No one said anything about it being to lean in the low end.
Old Apr 3, 2008 | 07:43 PM
ChuckP's Avatar
Your timing is conservative because you are only running 1 degree at peak torque, and 11 up top. I run more on 91 oct.
You are knocking the entire pull. I would drop boost down a lil, lean out the AFR like everyone is telling you, the dial in more timing.
Old Apr 3, 2008 | 09:37 PM
Chuck I thought the same thing but its not knocking the whole log. The knock is on the otherside, when it went to txt format it threw everything off a column or two. Its scattered 1's and 2's.
Agressive with a stock turbo at 25psi is 5-6's at peak torque and then 14 or so by redline. On the IX's you can do some things with MIVEC to stave off knock. Stock turbo and stock cams I used to see 285-290 at 25psi, threw in an HKS280 exhaust back in the day and it would hold 300 down low really well. With a bigger turbo it hits the same load but higher up now, so I dont really have mine rescaled over 320 but you can kind of see the idea in this old one:
Its an 05 VIII that I rescaled along time ago. It was having some knock issues (and a stock LICP) but even then substitute the 2's (@3000-3500 rpm and 270-300 load) for 4's and thats how the map should have looked.
Old Apr 3, 2008 | 09:51 PM
ChuckP's Avatar
You right. What data is RequestID00 logging?
Old Apr 4, 2008 | 10:05 AM
93 3gt vr4's Avatar
I didn't think i saw much knock either. But here are my ignition and timing maps. Do i have to make both fuel maps the same?
Old Apr 4, 2008 | 11:00 AM
MR Turco's Avatar
I would seriously lean it out a bit. The knock could be from running too rich. otherwise it looks pretty good.
