MAp tracer will not work.
Old Apr 4, 2008 | 06:51 PM
skold's Avatar
i cant get map tracer to work and ideas?
Old Apr 4, 2008 | 11:14 PM
lemmonhead's Avatar
inorder to see the full resolution of the map, 300 load. you have to put a copy of your rom in the evoscan ROM folder.
pM me if you have problems or dont understand.
Old Apr 4, 2008 | 11:21 PM
fostytou's Avatar
EvoM Community Team
Nice Avatar!
What version of evoscan are you using? The 2.2b maptracer was not working for me when I tried.
Old Apr 5, 2008 | 04:18 AM
skold's Avatar
2.1, i have my room in the rom folder
Old Apr 6, 2008 | 12:28 AM
lemmonhead's Avatar
did you right click the grea area, then choose your rom id, then your xml file?
Old Apr 6, 2008 | 08:09 AM
3gturbo's Avatar
There appears to be a bug in 2.0 and later that if you change any value at all in the config file (like injector scaling size) it screws the map tracer big time.
Old Apr 7, 2008 | 05:34 PM
skold's Avatar
sometimes it works and some times it doesnt. now, now data loggin doesnt work at all since i edited my xml
Old Apr 8, 2008 | 05:01 AM
DCsleeper's Avatar
I am using evoscan 2.1 and maptracer is not working either. I have successfully loaded my xml file and hex files from my ecuflash folder. The load scale is correct as well as the high fuel and timing maps. The issue is that when I check any of the parameters on the left nothing displays.
If I use the samples everything works fine.
Suggests and fixes please.
Edit. Actually using version 2.1 as it now states
Old Apr 8, 2008 | 05:07 AM
TeStUdO's Avatar
You must have screwed up your editing. I hope you saved your stock xml.
DCsleeper, try uninstalling 2.2 and installing an older version of EvoScan to see if it helps.
Old Apr 8, 2008 | 05:12 AM
DCsleeper's Avatar
Just realized I typed the wrong version in my post. Corrected now.
I am using version 2.1 still have problems.
Old Apr 8, 2008 | 01:26 PM
travman's Avatar
2.0 worked for me - upgraded to 2.1 and it doesn't work anymore. Waiting for 2.2 to see if it was a software issue.....hoping it is.
Old Apr 16, 2008 | 05:17 AM
DCsleeper's Avatar
I seem to have found the solution to my problem using EvoScan 2.1 and map tracer.
When I switched over to logging 2BYTE LOAD and 2BYTE RPM the map tracer graph worked perfectly on EvoScan 2.1.
Old Apr 16, 2008 | 05:21 AM
Appauldd's Avatar
Yup I have the same problem too.
Ahh the joys of trying to tune our cars....what fun it is.
Burnhad91
Jun 2, 2016 06:35 AM
Big Bald
Aug 11, 2013 05:11 PM
Miller_x
Feb 10, 2012 02:12 PM
06EvoIXmr07
Nov 3, 2010 10:45 AM
mr2driver
Jul 28, 2008 03:47 PM
