Can't get Mitsulogger to work
Old Apr 15, 2008 | 11:06 AM
premo's Avatar
So I downloaded the newest Mitsulogger, unzipped the file, and when I go to start it from the folder that is created, the little "dashboard" box pops up for a split second, then I get a Windows error message. Am I doing something wrong that I don't realize. I tried searching, and didn't find anyone else having similar problems. I'm a total noob to tuning, so be gentle lol
Old Apr 15, 2008 | 11:24 AM
zeus1's Avatar
do you have .NET framework 2.0 or higher installed on your computer?
Old Apr 15, 2008 | 02:04 PM
premo's Avatar
I do, but I'm going to do a re-install to see if that fixes anything
Old Apr 15, 2008 | 03:01 PM
premo's Avatar
Nope, still not working. Might just go ahead and get EvoScan
Old Apr 15, 2008 | 11:22 PM
codgi's Avatar
What is the error message?
Old Apr 16, 2008 | 04:28 AM
MalibuJack's Avatar
The only error messages you would typically get are either .NET framework, or a driver problem, and those are rare.
Are you attempting to run the application in windows Vista? If you are, make sure the application shortcut is set to run as administrator.
Also, when you unzip the file, all of the files in there HAVE to be unzipped into the same directory. If you don't, it will generate an error.
Thats all the common things I can think of.
Old Apr 16, 2008 | 06:26 AM
MalibuJack's Avatar
Oh, it will get an error if you run it from a network share... but that doesn't normally`apply to most users
Freddy302
Jun 23, 2009 02:20 PM
honki24
Sep 10, 2007 12:30 PM
kreionic
Mid-Atlantic Region
Feb 7, 2007 05:43 PM
MalibuJack
Feb 1, 2007 10:46 AM
krillin
Jan 25, 2007 11:53 AM
