Need help re scaling maf
Old Apr 4, 2008 | 06:55 PM
skold's Avatar
so i went to re scale my maf today, and i hooked up my mac mentor scan and my fuel trims are all at 0.0 pretty much all the time.
any ideas
Old Apr 4, 2008 | 07:25 PM
bnice01's Avatar
what does evoscan or mitsulogger say for STFT and LTFT
Old Apr 5, 2008 | 04:17 AM
skold's Avatar
evo scan has nan error, ill try mitsu logger today
Old Apr 5, 2008 | 04:47 AM
skold's Avatar
evoscan 1.0 says
fuel trim mid 103.90
fuel trim high 136.72
no short and long,
i also have no rear o2, im running a wideband instead
Old Apr 5, 2008 | 05:18 AM
Ph3n1x's Avatar
Search next time.
https://www.evolutionm.net/forums/sh...ht=rescale+maf
Old Apr 5, 2008 | 07:11 AM
bnice01's Avatar
the formula in evoscan is probably wrong thats why your fuel trims look like that
On your cpu follow this path:
-C:\Program Files\EvoScan\EvoScan v1.0\DataSettings
-You will see a xml file in there, right click on it and select to open it up in wordpad or notepad doesnt matter which one you pick
- Find Fuel Trim LOW, Fuel Trim MID, Fuel Trim HIGH, and 02 Feedback (its not that far from the top, Look for <DataListItem DataLog="N" Color="" Display="Fuel Trim Low" and you will see the rest)
-Remove all 4 lines and replace it with the code below
-Now you should be able to log fuel trims in evoscan
Code:
        <DataListItem DataLog="N" Color="" Display="Fuel Trim Low (LTFT)" LogReference="FuelTrim_High" RequestID="0C" Eval="(0.1961*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="200" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes="Long Term Fuel Trim - Low" Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="" Display="Fuel Trim Mid (LTFT)" LogReference="FuelTrim_Mid" RequestID="0D" Eval="(0.1961*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="200" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes="Long Term Fuel Trim - Mid" Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="" Display="Fuel Trim High (LTFT)" LogReference="FuelTrim_Low" RequestID="0E" Eval="(0.1961*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="200" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes="Long Term Fuel Trim - High" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Oxygen Feedback Trim (STFT)" LogReference="O2FeedbackTrim" RequestID="0F" Eval="(0.1961*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="200" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes="Short Term Fuel Trim - When the fuelling is under closed loop control by the lambda sensor(s), this refers to the amount of fuel added or subtracted from the value retrieved from the fuel map. -5% would mean that the ecu is fuelling 5% less than the map says in order to achieve the ideal air/fuel ratio. Under high loads, the ECU switches off closed loop control, and uses values from the map. At this point, you will see AFC drop to 0%. This is why it is important that fuelling mapping is accurate (or at least rich) at high loads - the ECU does not compensate for errors here. " Priority="1" Visible="false" />
mitsulogger will work right off the back and does not require any editing
But to explain the different meaning:
O2 feedback is STFT
Fuel Trim Low is LTFT for idle
Fuel Trim Mid is LTFT for crusing
Fuel Trim High is LTFT for WOT
The main ones you want to focus on trying to get your fuel trims in order is 02 feedback, fuel trim low (log this @ idle like explained), and fuel trim mid (log this @ a steady cruise like explained)
CtSilver03Evo
Apr 16, 2014 10:56 AM
apilarinos
Dec 9, 2012 05:43 PM
goodhart
Jul 3, 2011 10:37 AM
Kierkegaard
Aug 14, 2007 09:31 PM
