Injector Scaling Questions...
Old Apr 13, 2014 | 07:13 PM
CtSilver03Evo's Avatar
Hey Guys,
I recently installed a set of ID1000 injectors. I started scaling with some numbers I found in the massive injector scaling thread and adjusted from there. I have my LTFT Idle and Cruise both near +/-0% while driving steady for 20mins or so.
Now... When I come into boost at low throttle the car is very rich, but on the under full throttle the car is running on the leaner side. Is this still something I should be playing with the deadtimes on? OR is this something I would tune out elsewhere?
Pretty much the settings on the forums worked, but I had to increase the injector scaling about 8% and didn't touch the deadtimes. The car was tuned pretty well before on the stock system, but with installing the new injectors - will I have to re-scale the MAF?
Thanks!
Old Apr 16, 2014 | 10:56 AM
fostytou's Avatar
EvoM Community Team
By deadtimes are you referring to the injector latency vs battery voltage? If so you should probably adjust these. I think FIC injectors come with a sheet that gives you what it should be.
That could also explain why you had to go 8% higher.
Frankly, I recommend MAF tuning for any car with a change to the intake (pre turbo) or a major fuel system change. That should be your last step though.
Either way your injectors simply won't run the same as the factory ones. It may be close, but a re-tune of the fuel tables is almost always recommended (especially if your WOT AFR is leaning out).
Fast_Freddie
Oct 30, 2023 01:56 AM
goofygrin
36
Jun 27, 2017 11:17 AM
kmcconn9
Nov 28, 2009 05:29 PM
Khalid
Jun 11, 2008 03:19 AM
razorlab
May 11, 2006 11:33 AM
