About to get back into speed density testing
Old Apr 8, 2008 | 04:19 PM
Asmodeus6's Avatar
Thats why I went one step at a time. I should have my evo X map sensor in this week. I'll get that running and logging. Then - I will finish the SD install and yank out the MAF. Where did you mount your AIT?
I have Buschur's FMIC and SS hard pipes and I wonder if it is thick enough I can tap it to get the GM AIT to thread well enough to seal. And I can't find a 3/8th's SS nut or bung to weld on.
How much richer JB? Honestly what I did was take from like 4000 rpm + and like 160 load + (the whole bottom corner) and flashed it all like 11.X-1. And cut lean spool off at 4000 rpm. Then I turned the A/F tracking on - set its range +15% -10% and made it activate real fast. I think it would solve your problem rather painlessly. With lean spool off the car was horridly rich. So I got it back in the neighborhood of where I wanted to be / then turned A/F tracking back on.
Voila... done.
Old Apr 8, 2008 | 09:52 PM
BluEVOIX's Avatar
Originally Posted by mixmastermatt
I have a MAFTPro, and I tried using it's speed density setup with a 3bar GMMAP sensor. I could never get the throttle tip-in settings correct so it would lean out terribly during large throttle changes. I even had turbobob try to help, bu it never worked for me. I ended up getting a GM MAF and running like that for awhile until the MAF sensor **** itself.
BTW, Eric, the MAFTPro can do speed density, the MAFT does translation only.
BlueEVOIX, that is basically what I am doing. I have a JDM 3bar MAP that is taking the place of the stock MAF sensor.
Oh lol. I'm still in the learning game and didnt know/realize speed density was another name for MAP lol. I was thinking speed density = another name for blow through maf or something...
Ok it makes sense now.
Old Apr 9, 2008 | 03:04 AM
recompile's Avatar
Originally Posted by Asmodeus6
I will be switching over to SD mode soon. I 'm using the JDM map instead of the GM 3 bar to keep installation simpler. Bob has already made a provision at my request in the newer updates to work with it instead of the GM 3 Bar.
That's excellent news for the MAFT Pro! Is the IAT sensor just a regular GM IAT? If so, I can save $115 and just use my JDM MAP and the GM IAT I already have.
Of course, it's still more expensive than using the stock ECU
Old Apr 9, 2008 | 04:26 AM
dan l's Avatar
We are running the MAF Translator on a friends evo. He loves it. I know the 3" GM maf can go well into 700whp as a friend of mine did it years ago.
The MAFT Pro is nice. I run it. I've done wideband feedback and it works well.
Old Apr 9, 2008 | 05:32 AM
Tuner@Swift's Avatar
If anyone reading this wants a MAFTPro, I'll let mine go for $250.
Old Apr 9, 2008 | 01:23 PM
Asmodeus6's Avatar
Correct.
Bob has been stellar about adding whatever revisions we think will work best for it.
Thats a steal.
Even if its just the box / with no wires you can get all the odds and ends easily from FT.
Old Apr 9, 2008 | 01:39 PM
recompile's Avatar
SOLD, to me
Evo_9xxx
Nov 7, 2020 04:58 AM
nsheasley
Jun 3, 2015 08:44 AM
addicted2speed
Aug 4, 2012 11:12 PM
bbyevo8u
14
Aug 28, 2010 04:40 PM
ballistic speed
24
Mar 14, 2006 10:00 PM
