how-to: Log AFR from the LC-1 w/o a serial cable
Old Jan 4, 2010 | 08:41 PM
  #286
donour's Avatar
Originally Posted by Drill_Sergeant
I just got the answer to this today from TouringBubble. The way he explained it, its not MUT12x. It is MUT1x, 2.
Correct. MUT request "12"
d
Old Jan 5, 2010 | 03:06 AM
  #287
vmrevo9's Avatar
Veteran: Air Force
thanks drill sergeant!
Old Jan 7, 2010 | 09:57 AM
  #288
steadly2004's Avatar
Originally Posted by travman
Does anyone know if this can be done with the AEM wideband? Run the blue wire into the ecu and the black wire to ground (those are the 2 wires that go into the serial connector)?
Just curious if there is a solution rather than logging the aem through a diy serial connector?
Basically I am working on tuning a car with a aem wideband and we cant get the serial cable to work - its wired correctly, and the computer is recognizing the usb to serial adapter (dynex) but evoscan just comes up with an error every time......
I am going to try flashing the V5 94170014 patch (he has 94170008 currently and the 14 is supposed to work) on his ecu for the rear O2 sim and thought maybe we can ditch the serial and log the aem through the ecu instead?
Any help would be appreciated!!
Originally Posted by mrfred
Call up AEM to ask what signal sent through the blue wire you mention. If its a voltage betwee 0 and 5 volts and they can give you the correlation between voltage and AFR, then you are in business.
I know there is a 0-5v output. I have the AEM Uego too and am curious to find out if this works.
There are actually 2 signal output wires, one for the serial cable (blue I think) and another maybe white? that outputs the 0-5v. I used the 0-5v when I was using a greddy-e-manage.
Old Jan 7, 2010 | 07:31 PM
  #289
Drill_Sergeant's Avatar
Veteran: Army
the white wire is listed at the 5v output according to the manual.
if someone has AEM's correlation between voltage and AFR, please share.
i'll try to call them up on of these days when im not busy at work...
Old Jan 8, 2010 | 05:42 AM
  #290
hediki12's Avatar
If someone has aem's correlation between voltage and afr, please share.
I'll try to call them up on of these days when im not busy at work...
+1!
Old Jan 8, 2010 | 05:50 AM
  #291
hediki12's Avatar
hey i dont understand math much but i did a few google searches and came up with this. the equations look like the ones you write let me know if it helped a bit.
http://www.rx7club.com/showthread.php?t=272828
for the uego
Old Jan 8, 2010 | 06:02 AM
  #292
hediki12's Avatar
also found this im hoping it doesnt only aplies to the aem ems but maybe some one can test it im waiting on my uego in the mail
page 5
http://www.aempower.com/images/produ...%2030-4100.pdf
Old Jan 8, 2010 | 02:06 PM
  #293
page 5
I think that page 5 is exactly what they're talking about. Now if we can just get it into a good single equation.
I think its (Voltage)(2) + 10 = A/F for gasoline
Old Jan 8, 2010 | 02:09 PM
  #294
hediki12's Avatar
umm the 1st link had some equations i don't understand them really lol. check it out
Old Jan 8, 2010 | 02:24 PM
  #295
Yea, that doesn't make any sense to me at all, lol. Poly--something or another equations.
Old Jan 8, 2010 | 02:51 PM
  #296
hediki12's Avatar
seems like your right... i cant post the site for some off reason....
Old Jan 8, 2010 | 05:11 PM
  #297
Veteran: Army
from AEM's instruction manual
how do we use this to make for more accurate and faster logging?
Old Jan 10, 2010 | 01:01 PM
  #298
Veteran: Army
using this formula 0.03913*x+10 for the AEM UEGO
the AFRs read very close to the actual gauge. its a difference of +0.1 to +0.2 but it might just be a time issue
Not sure which of the two is more accurate but they are very close and reads fast.
here is a side by side comparison
Old Jan 10, 2010 | 01:34 PM
  #299
Danieln's Avatar
I log via serial to usb a LM-2 in Evoscan.
Evoscan formula is (x) as you know.
Do you use this formula for AEM uego in order to get the proper value?
What I suspect is that my Evoscan will have a delay when I read it via serial to usb.
Do I need to use maybe a formula also??
Thanks
Old Jan 10, 2010 | 02:45 PM
  #300
Veteran: Army
mrfred, or anyone who can help, how should i adjust my formula to make it read more closely to the gauge itself. my AFR's are about +0.1 to +0.2 compared the gauge.
my values im using are 19.98-10.0, so the current formula is 0.03913*x+10 for the AEM UEGO
Danieln, the "x" is strictly for logging with serial cable under the "external wideband" option.
the placement for the formula you input is for the "wideband AFR" option shown here:
