Tuning 272's cams
Old Apr 11, 2008 | 03:19 PM
ant_turbo's Avatar
Tuning 272's cams
How much tuning does it take to tune cams?/ And what's involved in tuning wise....
272's coss cams,,,
THANKS...
Old Apr 11, 2008 | 03:20 PM
4WS Tuning's Avatar
set the boost
set the afr
adjust the timing
Its just like tuning any other mod, but you'll need to play with the idle as well if youre having dipping or stalling issues.
Cheers!
Old Apr 11, 2008 | 03:36 PM
ant_turbo's Avatar
What about fuel maps??
THANKS....
Originally Posted by 4WS Tuning
set the boost
set the afr
adjust the timing
Cheers!
Old Apr 11, 2008 | 06:49 PM
draconx's Avatar
afr is fuel maps man.. 4WS FTW!!!!!!!!!!!!!!!!!!!!!!
Old Apr 11, 2008 | 09:53 PM
Jack_of_Trades's Avatar
Don't set the timing at idle too high or you'll get stalling issues during deceleration and you'll have a hard time getting a consistent AFR at idle. Setting it too low will make the idle more lopey, rough and also hard to get a consistent AFR at idle.
Old Apr 11, 2008 | 09:57 PM
4WS Tuning's Avatar
+1 8-10 is usually good
Old Apr 13, 2008 | 11:22 AM
Oracle1's Avatar
9-11-14*
Old Apr 13, 2008 | 12:48 PM
I'll all depends on the Brand of cams too.
I noticed that 272 Comp cams cant handle higher than around 7* at idle, with a bump in idle RPM as well. Anything higher caused too much rpm dip/stalling during decel. BC cams cam pretty much use the stock settings.
TwistedEvo8
26
Aug 7, 2016 06:48 PM
socalx_dsm
Jun 9, 2015 05:38 PM
racer135
Apr 30, 2009 03:30 PM
EE
Mar 31, 2008 02:32 PM
LpBevoEvo
11
Jun 29, 2005 07:34 PM
