download evoscan .97
Old Apr 13, 2008 | 07:19 PM
myrt's Avatar
Veteran: Air Force
Hello,
I have paid for evoscan and everything and i have my serial number, i was just wondering if anybody had the link so i can download the older version of evoscan. I am running vista and 2.0 and 2.1 wont work.
thanks
Phil
Old Apr 13, 2008 | 08:29 PM
ChuckP's Avatar
They work just fine. I use vista and ive had no problems with either version.
Old Apr 13, 2008 | 10:08 PM
myrt's Avatar
Veteran: Air Force
Any ideas why the timing reads -20 and all the rest are 0? it says link engauged. ECUFlash works perfect so i know its not a cable problem. Which vista are you using?
Old Apr 14, 2008 | 11:32 AM
ChuckP's Avatar
no idea. Is this for an evo? or stratus?
I was under the impression that there is only 1 vista? Its the most current version i know that.
Old Apr 14, 2008 | 12:10 PM
hellcat's Avatar
There is only one vista but there are a few versions.
Old Apr 14, 2008 | 03:41 PM
3gturbo's Avatar
Evoscan 2.0 and above are screwed if you run anything but stock injectors map trace will not work among other things
Old Apr 19, 2008 | 09:38 AM
myrt's Avatar
Veteran: Air Force
This is for a stratus (yes evoscan works with a stratus) and there is Vista home, Vista Buisness, and Vista Ultimate (which i run) and all those verson come in eithher 32 bit or 64 bit (which i run). 97 worked for me with vista but i dotn have the install file anymore. Anybody?
Old Apr 21, 2008 | 06:57 AM
fugiwara's Avatar
pm me your email address, i have the 0.97 version.
