Tuning with an External WG dump
Old Apr 14, 2008 | 08:43 PM
Nuked's Avatar
Anyone else tuned an Evo with one? I have been getting knock counts, but the timing/AFR/boost is rather conservative. Just trying to see if the sensor is picking up the dump.
SQ
Old Apr 14, 2008 | 09:12 PM
turboracer's Avatar
I don't get knock with mine. 38mm open dump near first down pipe bend pointing toward the back of the car.
Old Apr 14, 2008 | 11:30 PM
Asmodeus6's Avatar
44mm dump right off the manifold down by the down pipe and under the car.
It is rediculously loud. I don't have any troubles.
Old Apr 15, 2008 | 12:06 AM
RazorLab's Avatar
If the dump tube isn't touching anything I don't see why it would be creating knock counts.
Old Apr 15, 2008 | 02:34 AM
spdracr's Avatar
i have my car running open downpipe right at the first bend facing down lol just a straight shot and i dont have trouble
Old Apr 15, 2008 | 07:03 AM
Nuked's Avatar
Ok, thanks guys. I will start looking at other areas then. Just wanted to make sure the open dump didn't cause a problem before I started onto other things.
SQ
Old Apr 15, 2008 | 02:44 PM
TouringBubble's Avatar
I've seen random knock counts with an external dump on the stock turbo. Strangely, it was always while heading East. Go west and knock was gone. Toluene, low boost, low timing didn't get rid of it. I don't think the dump tube was hitting anything.
Old Apr 15, 2008 | 04:01 PM
jid2's Avatar
If the dump isn't far enough away or under the car it will create extremely high under hood temps and raise the intake air temp as well. Maybe look into that.
