reading/access on a locked ecu, now identifying the rom
Old Apr 18, 2008 | 01:23 PM
jason4656's Avatar
i have a rom, would like to be able to access/read it, its from a 9 jdm gsr that had been previously locked by ecutek i beleive
any ideas what i should match it with?? defintions?
Old Apr 18, 2008 | 01:31 PM
zbomb's Avatar
1st: Read this:https://www.evolutionm.net/forums/sh...d.php?t=245980
2nd: Go to the site in the OP's sig. Join. In the site you will find ECU unlocker. It will allow you to pull the rom out of the ECU as well as reflash it. If you want you can change the settings of the ECU to permanently unlock it once you've gained access. This is the direct link to the unlocker but you will need to join to access it:
http://www.aktivematrix.com/forum/dl...24187d51065f30
Then you should throw out a thanks to MalibuJack for making it available.
Old Apr 19, 2008 | 01:08 AM
jason4656's Avatar
been there, done that, downloaded it, it was the only way i could pull the rom from the car, however the versions of ecuflash i found, 1.28 and 1.29a crashed every time i tried to use them after install, just wouldnt start, i have no idea why, however now i have the rom, i cannot adjust it cos of the definitions issue.
also found with using older versions that, when you pulled a rom from a car that worked with say 1.34 ie i had the correct xml file for it in the folder, it just opened, however when i pulled it with 1.28 it asked me to match or give base file from a list, but the actual xml file that was already in the folder, was not specified to copy the definitions from! confused with it all
thanks
Old Apr 19, 2008 | 03:11 AM
jcsbanks's Avatar
88570008.xml will display the maps for any JDM Evo IX I've come across - GT, RS, GSR, MR, FQ. If 88570008 is not the ID of the ECU, just tell it to inherit 88570008.
I still use Ecuflash 1.29a, you need a tweak to the xml file "endian" if you use later versions with an older xml.
Old Apr 20, 2008 | 04:32 AM
jason4656's Avatar
ok so im a bit lost with it now, if i install older version, it just crashes completely on opening, if i go back to new version i can open the roms that come in the folder with the program, but not the ones i have downloaded from the locked ecu, it forces the program to crash, and yes i do have that xml file in the folder already
any suggestions? how do i wipe everything completely? can someone give me a list of all installed system files and reg entries?
thanks
Old Apr 20, 2008 | 04:51 AM
jcsbanks's Avatar
This is one of the reasons I stuck with 1.29a. I would uninstall everything including all the drivers and then try to reinstall your chosen version, if not reinstall Windows and try again. Don't know if it works in a virtual machine.
Old Apr 20, 2008 | 06:04 AM
jason4656's Avatar
so do you know all the drivers to uninstall??
thanks
Old Apr 20, 2008 | 09:08 AM
jcsbanks's Avatar
Look in add/remove programs under Windows Driver Package - Tactrix.
EvoPower81
May 29, 2019 11:04 AM
domyz
Jul 30, 2016 09:40 PM
br3akrboi
Dec 6, 2015 11:40 AM
Synergy87
Oct 30, 2015 06:56 PM
MonacoGP
Jun 1, 2010 01:17 PM
