Stock Turbo 369bhp
Old Apr 25, 2008 | 10:11 PM
roberttonge's Avatar
Stock Turbo 369bhp
Make: Mitsubishi
Model: Lancer Evolution VII
Registration Number: PL006
Weight with driver: 3,450 lbs
Horse Power
Stock Horse Power = 280 bhp at 19 PSI
Past Power = 356 bhp at 20 PSI date 2007-04-03
Current Power(1) = 369 bhp at 20.3 PSI date 2007-11-24 - Evoscan and about 405.63 HP at the flywheel.
0 - 60 = 4.294 sec
1/4 mile = 12.977 sec @ 105.29 mph
Weight = 3220 lbs
Engine/Performance Modification
Cams - GSC Exhaust 272 duration 10.2
Cams - GSC Intake 272 duration 10.8
AEM Perfromance Air intake System
Front Mount Intercooler - Greddy Trust
Aluminum Intercooler Pipes
Header Manifold[/color]
O2 Housing - O Tomei EVO Expreme
Down Pipe 3’- O Tomei
Test pipe 3" - Mc Millan
Full Exhaust 3'- Greddy Trust
Catback Exhaust - GReddy Titanium Exhaust
Clutch - ACT HDSS 475 bhp
Clutch Line - Steel Braided
Boost Controller - Greedy Profec B-Spec II
Re-flashed ECU 20.5 psi– by http://www.ttp-engineering.com
Fuel Pump 550cc - Walbro
Blow off Valve Greedy Type S
Oil Catch Can
Spark Plugs - HKS
Exterior Modification
Vortex Generator
F1 Carbon Fiber Mirrors
Interior Modification
Turbo Timer - Greedy Full Auto Timer
Boost Gauge - Auto Meter
Wide Band AFM/Data Logger - Zetronix http://www.zeitronix.com/
Evoscan - Full Data logger of the Ecu http://www.limitless.co.nz/evoscan/
Ecu Flash - for Ecu modification http://www.openecu.org/index.php?title=EcuFlash
G-Tec Pro RR
Old Apr 25, 2008 | 10:29 PM
RazorLab's Avatar
I can make 40 more whp in software dynos if I use no smoothing too.
Old Apr 25, 2008 | 10:41 PM
RoadSpike's Avatar
Evoscan has always measured inaccurately after a gear shift for me. I think with a single gear pull it does alright though.
Old Apr 25, 2008 | 11:54 PM
RazorLab's Avatar
Not talking about that. Load a single gear pull, then plot it in the dyno. Then use 0 smoothing like the OP and watch your peak HP sky rocket.
Old Apr 26, 2008 | 01:22 AM
Please advise the best way to log data to get the most accurate reading. The intention was to get feedback as to how realistic this program is, as there are no dyno's on my island.
0 smoothing????
Thanks for your advise in advance (Patat Mamaw).
Old Apr 26, 2008 | 04:12 AM
recompile's Avatar
EvoScan's estimates are useless in my opinion.
DataLogLab is a much more reliable tool, and even then, you must use some degree of smoothing... typically 4-6 ticks is common, but it all depends on how fast you are logging. The faster you log, the more smoothing you will need.
Robert, the graph should be a smooth curve, not a jagged spikey mess. Those spikes are not your actual horsepower.
Old Apr 26, 2008 | 03:22 PM
R. Mutt's Avatar
I agree. From the logs I've taken of Trinidadian evos (VIIs,VIIIs and IXs) evoscans road dyno is bogus.
What octane do u get in DR and what's your 1/4 time and trap speed? If I had to take a wild guess - I'd put you closer to the 330-350 range.
Old Apr 26, 2008 | 06:15 PM
Jack_of_Trades's Avatar
I've had the evoscan's #'s be accurate to within 5whp compared my own and other friends dynojet readings. The #'s are about as irrelevant as real dyno numbers. You just need a setup that is consistent with itself so you can make A-B comparisons to see if you are increasing or decreasing performance.
Old Apr 26, 2008 | 06:19 PM
RoadSpike's Avatar
Anyone care to elaborate on why after a gear shift Evoscan reads a high "dyno" number?
Old Apr 27, 2008 | 07:02 AM
Not DR but DOM, closer to TNT.
Octane 95, i was told
12.9 but that was smoking the tires. I will do another one soon, but I have to change the suspension bushings.
0 - 60 = 4.294 sec
Weight = 3220 lbs +driver 225lb
Old Apr 27, 2008 | 09:13 AM
dan l's Avatar
That weight/hp/trap is only about 300whp worth of power.
How do you get 0-60? Are you using a g-tech or are we talking a REAL track?
Old Apr 28, 2008 | 05:42 PM
jdmxero055's Avatar
Nice numbers for stock turbo
Old May 3, 2008 | 06:11 AM
I used the new Gtec pro RR.
Old May 4, 2008 | 12:55 PM
lurkerpika's Avatar
then those numbers must be right if its new and RR
