My first patch for E85
Old Apr 28, 2008 | 08:24 AM
JoeBee's Avatar
Yesterday I have done my first ECU patch for my 99860002 Evo VII Rom.
I must test it first, but the car is already running, so the patch was not too bad.
With the ICS Auto Switch hold, I can switch between 4 steps (0 to 3). The ICS Led will blink that many times when you press it short.
For each step an own injector scaling can be used.
The patch will interpolate between my alternative E85 map and the high octane fuel map with the weight of the steps. At step 0 value from high octane map is used, at Step 3 value from E85 map is selected. During the other steps the value will be interpolated.
After the value is found, the interpolation with the low octane map is already done
The same happens with the ignition map.
Later this can be used with a flex fuel sensor.
Nothing special if you already use tephra's patch, but it was not available for my ECU ID so I have try this as my first work.
Old Apr 28, 2008 | 03:55 PM
tephra's Avatar
nice work!
pretty good effort for a first patch release
i am still thinking about how we are going to interpolate for E85, unfortunatly boost and injector scaling don't "interpolate" nicely...
Old May 8, 2008 | 01:46 PM
JoeBee's Avatar
Some ideas for load logging:
Right befor the table lookups there is a variable filled with one of the loads variables. These variable is used for the table lookup and has the same scaling as the load row. The problem is, that this variable is overwritten during many other table lookups.
In my patch I copy this variable to an extra ram address. Then I divide it by 4 so it can be logged as one byte (after editing the MUT Table).
The same copys I do with the found table values (fuel/ignition) befor they are "corrected" by some routines, so I can exactly compare if I hit the right cell.
Later with Johns DMA logging the variables can be logged in realtime.
By the way. I have problems with the logging variable called AFRMAP.
I cannot found the program part where this variable is written. So I don't trust this viariable.
Have anybody else found where it is written?
Old May 8, 2008 | 02:55 PM
jcsbanks's Avatar
There is a group of engine variables that seem to be passed around as a block. You'll see it if you trace back from AFRmap in the MUT table - only one routine reads it directly, and the other reference is to this block. That might actually be an interesting block to log with DMA. I'll look into it.
Bez has been applying DMA to his Evo 7 ROM. I've posted a test version for Tephra's 9. If they give good feedback I'll start rolling it out.
Old May 9, 2008 | 01:10 AM
JoeBee's Avatar
Found it. Thank you John. The AFRMAP is written after some corrections
Code:
ROM:00014010                 mov     r0, r10
ROM:00014012                 mov     #h'50, r0 ; 'P'
ROM:00014014                 mov.l   @(r0,r1), r11   ; AFRMAP write indirect
ROM:00014016                 mov.w   r10, @r11
r1 is set to this Block of Addresses. At Byte Position 0x50 is the AFRMAP Variable (in WORD size) for my ROM it is here:
Code:
ROM:00009158 dword_9158:     .data.l h'FFFF          ; DATA XREF: sub_FF08:off_FF84o
ROM:00009158                                         ; ROM:off_12248o ...
ROM:0000915C                 .data.l unk_FFFF88E4
ROM:00009160                 .data.l unk_FFFF88E8
ROM:00009164                 .data.l unk_FFFF88F2
ROM:00009168                 .data.l unk_FFFF88F6
ROM:0000916C                 .data.l unk_FFFF893A
ROM:00009170                 .data.l unk_FFFF890E
ROM:00009174                 .data.l ADC_9_FrontO2_Volt
ROM:00009178                 .data.l ADC_A_RearO2_Volt
ROM:0000917C                 .data.l unk_FFFF8902
ROM:00009180                 .data.l unk_FFFF87EA
Old May 10, 2008 | 03:59 PM
JoeBee's Avatar
Question to the E85 cracks.
This morning I need to crank my car 4 times to start with E85.
Which parameters in ecuflash can be changed to help the starting?
Old May 10, 2008 | 06:31 PM
Jack_of_Trades's Avatar
I would mess with the 500 rpm igntion timing. The reason there is 15% gasoline is to aid with cold starting but apparently you need more help than that,lol. I would assume messing with the open loop fuel cells in the lowest rom range might help too since its in open loop during cranking. E85's stoich is a lot richer than gasoline so maybe it needs richening in that area for start-up?
Old May 11, 2008 | 01:26 AM
JoeBee's Avatar
Retard or advance timing.
ast
Aug 19, 2025 07:09 PM
richardjh
Nov 6, 2024 04:41 AM
Deepnine
Oct 29, 2008 10:44 AM
Jim in Tucson
18
Sep 17, 2007 05:59 AM
BigBoogieman
36
Feb 27, 2005 07:06 PM
