Ecuflash guru's...help needed
Old May 2, 2008 | 05:26 PM
Copenhagen's Avatar
I'm trying to help keep a big burbo spooled between shifts and on a launch. I was looking over the thread "Show me your fully tuned maps," and saw a few people pulling some timing on throttle lift-off to get a rich condition similar to a anti-lag. I have been playing around with it and haven't had any luck. This is on a '03 VIII if that makes any difference. I also looking to get the same condition when launching on the factory stationary rev-limiter. Currently I am at 6k and I'm getting about 10-11psi. I don't really want to raise it but I would like to cut some timing or add some fuel to get an effect similar to a launch control set-up. I have done plenty of searching but haven't quite had the result people seem to describe so I made this thread to see if I could get some help. I know I won't get stand alone type results but I'm trying to get a little help from the stock ecu until I cant get a stand alone. All help is greatly appreciated. Thanks,
Robert
Old May 2, 2008 | 06:00 PM
JohnBradley's Avatar
You need to add NLTS to your ROM...well use a NLTS ROM I mean.
Old May 2, 2008 | 06:04 PM
Copenhagen's Avatar
I do use that but I would like to help it out a little bit with more of a low timing/rich condition as I still a good amount of psi between shifts.
Old May 3, 2008 | 06:07 PM
Copenhagen's Avatar
Bump for help
Old May 3, 2008 | 06:29 PM
nikkadanny's Avatar
sounds like you have a pretty big sized turbo, when does it hit full boost
Old May 3, 2008 | 06:36 PM
spdracr's Avatar
if you change the timing in the 140-180 load cells at 6k to 6-8* of timing that usually lets you get about 12-14psi on the 2step just play with the timing and fuel there until you get results you like.
Old May 3, 2008 | 06:45 PM
Copenhagen's Avatar
Thanks I'll try that. What about on lift-off? I tried retarding the timing in the 0-30 load column from 5k-7500 and tried adding a little fuel but no dice.
Old May 4, 2008 | 03:24 AM
spdracr's Avatar
thats not gonna help much since its not powerful enough to spin it. i have it on my stock turbo but nothin. even if you had a real anti lag setup it would hurt your turbo more than its gonna help anything. just use NLTS and you should have an issue between shifts
Old May 5, 2008 | 02:03 AM
Copenhagen's Avatar
Bump for anymore help
Old May 5, 2008 | 06:42 AM
TouringBubble's Avatar
well, if you are using NLTS than you never technically "lift off" so what you are asking about would be useless. Using NLTS you'll only drop to the 140-170 load range and you don't want -10º of timing there as drivability will likely be affected.
Now, if you are 100% sure that you'll never be past 6000 RPM or so at part throttle (which is likely I guess) then you can pull the timing and see how it works. Just log a pull and see where the NLTS puts you load and RPM wise. Then, pull the timing in that area. I believe the VIIIs are limited to -6º or something and you'll need to pull at least -10º ... do a search in this forum and I think someone (maybe Bez) posted the code to modify the timing limit for the VIII.
I have never tried this and honestly wouldn't on my own car. I have no idea what might happen ... good luck.
