Adding resolution?
Old May 7, 2008 | 12:55 PM
nightwalker's Avatar
Adding resolution?
Just wondering how some of you guys are adding resolution to the maps? I see it mainly with the timing map, but not so with the fuel map, so is it a timing map only thing? Just trying to smooth my cam power delivery. The power kicks in hard with the stock turbo around 3500 and that's the only place I'm getting 3-5 counts of knock, but timing won't help it. It's not consistent knock either.
Trying to see if I can add some resolution and smooth it out. Thanks.
-Pia
(...yes, like the foglights)
Old May 7, 2008 | 01:05 PM
merkzu's Avatar
You can sacrifice resolution at a rev/load range to increase resolution in another. Just change the load or rpm numbers at the top/side of the table. You can't just increase resolution though, since the table size can't be changed
Old May 7, 2008 | 07:23 PM
RazorLab's Avatar
What merkzu said.
Also since you have a 03-04 Evo and running 91 octane, I would suggest running a little less timing at 3500-4000 then you would think. Every single 03-04 Evo I have seen come through the shop is very sensitive in this area compared to 05+. I've had to run some with 0* there.
Old May 7, 2008 | 09:05 PM
Jack_of_Trades's Avatar
Originally Posted by razorlab
What merkzu said.
I'm havingt hat issue with mine right now, this is at 25psi on 93 though. Still, the 03-04's seem to be very touchy in this area. Not all, but a good amount for some reason.
01sporty
Mar 22, 2017 08:34 AM
mc14
70
Sep 2, 2015 12:25 AM
Eagle
Feb 23, 2012 03:51 PM
tkklemann
Mar 25, 2008 09:06 AM
AndyC
Oct 29, 2006 12:52 PM
