Can I use multiple patches ?
Old May 13, 2008 | 05:34 PM
SWOLN's Avatar
Somehow I deleted my "lean spool" when I decided to go through and clean up my desktop. So, after, deciding to just go ahead and install the Ecuflash 1.34 instead of the 1.30 I had, I was wondering. Is it possible to use multiple patches? Say one from the Tephra V5 patch (Yes, I donated. Did you?). ... but I'm confused because after watching the great vid attached to do the V5 patch, I realized that one would use there own base file.(88590015) How does that work when you are applying multiple patches. I mean, would I be using the same base file each time? ...or do I just do all the patches at the same time? Thanks to all who are helpful.
Old May 13, 2008 | 05:38 PM
TouringBubble's Avatar
Tephra's mods are pretty much the only common mods that require an actual patch ... patch being a modified ROM image. Most other things like ECU boost control, lean spool and 2-byte values only modify the data that's already present in the ROM and you can use all of those with a Tephra patched ROM.
Old May 14, 2008 | 12:25 AM
Asmodeus6's Avatar
Yep. I have the old Tephra patched rom. cel/nlts/valet + JDM map + 02 elim + all the 2 bytes, lean spool, among other things. All added to the existing patched rom. But all those do not actually require a patched rom - but are simply manipulated data in ecuflash.
Old May 14, 2008 | 12:32 AM
tephra's Avatar
Yeah you can as long as you use the tephramod ROM as a base.
richardjh
May 24, 2026 12:49 AM
richardjh
Nov 6, 2024 04:41 AM
03whitegsr
Oct 8, 2017 08:16 AM
BarryC
Sep 10, 2009 12:22 PM
