27.5 psi on 91 octane maps
Old May 14, 2008 | 10:09 PM
RazorLab's Avatar
Awhile back I posted my maps that I used for a 100octane tune on a stock turbo.
You can see that here: https://www.evolutionm.net/forums/sh...d.php?t=254369
Figure I would continue with this and post my maps that I am currently using to run 27.5 psi on 91 octane.
Here they are:
For more info on this tune, with dyno sheets and visual logs see: https://www.evolutionm.net/forums/sh...d.php?t=340451
Old May 14, 2008 | 10:45 PM
tephra's Avatar
far out.. stock turbo? or green as per sig?
and is headstuds your only mod for keeping that baby tied down?
Old May 14, 2008 | 10:48 PM
RazorLab's Avatar
Green, mods listed in this thread: https://www.evolutionm.net/forums/sh...d.php?t=340451
Old May 14, 2008 | 10:56 PM
draconx's Avatar
what mods are on the car?
Old May 14, 2008 | 11:34 PM
RazorLab's Avatar
C'mon people, read the posts.
Old May 14, 2008 | 11:43 PM
scorke's Avatar
Things like this are great for the self tuning community, thank you razor lab
Scorke
Old May 14, 2008 | 11:44 PM
nonschlont's Avatar
Looks good! Timing seems mild. (granted Im in training) were u really hitting 21psi @ 2K? thats awesome! How long did u work on that map/tune? You were adding quite a bit of "upward" correction. I guess thats how its supposed to look when its dialed in...
Old May 14, 2008 | 11:57 PM
RazorLab's Avatar
Remember this is 27.5psi on 91 octane
Where are you seeing this?
I've found you need to bring back in upward correction when you set the Max Upward Correction Vs TPS down to 0. This table has created a huge jump in dialing in ECU boost to be even more solid. With it set at zero, the WGDC will never go over BWGDC. No more crazy overboosts with error correction!
Old May 14, 2008 | 11:58 PM
RazorLab's Avatar
Posting this map just made me realize I have a stray 12* in timing cell 260/8000. Oops. Time to fix that.
Old May 15, 2008 | 12:03 AM
joedr's Avatar
EvoM Moderator
Wow! That is some boost on 91!
I really appreciate that you share this with the community!
Congrats on the numbers!
Old May 15, 2008 | 12:06 AM
joedr's Avatar
EvoM Moderator
Exclamation
Good eye! I reviewed that zone and did not pick that!
Old May 15, 2008 | 12:26 AM
Asmodeus6's Avatar
Its really a service to have people as intelligent as yourself post things up like this. Its a shame the norm is cloak and dagger about maps.
I'd post mine but they would be gibberish. Maft Pro handles the bulk of the fueling situation so I basically have a bland A/F ratio in all the higher load cells. A/F tracking just does what I punch in on the unit.
My timing is almost identical... but on 93oct.
But I hold 25psi flat from spool to gear change.
I might be able to get away with another degree or two. But... then it will intermittantly knock. (And typically keep knocking) So I keep it about where you have it so I can get into it any time I want with only a single count here or there.
Old May 15, 2008 | 12:29 AM
nonschlont's Avatar
Thats some serious boost on pisstane.
I was lookin @ ur baseline boost table, but just came to the realization that it is probobly just that baseline... I am very new to the gm 3-port/ and the new baseline tables... Im awaiting my gm 3-port, and intend on making the transition over to PSI based control. Thank you for your contribution to the comunity! Its good stuff!
I noticed u have ur Max Upward Correction Vs TPS in volts... can u elaborate on this, As I have mine set up to tps% is there any advantage to having it set up to volts? Is this a PSI control mod?
Old May 15, 2008 | 12:54 AM
RazorLab's Avatar
No not really, I've just been too lazy to update my desktop computer defs.
Old May 15, 2008 | 01:09 AM
spdracr's Avatar
very nice job great info
