Looking for more maps, 80700010 Def
Old Jul 30, 2008 | 06:40 AM
  #76
sub7's Avatar
Haha, cool. wo men de nai cha bu hao he, chu tai wan ba.
Care to share your latest 80700010 xml?
Old Jul 30, 2008 | 06:48 AM
  #77
Mattjin's Avatar
Maybe on my next trip. I can see this turning into a chinese lesson, but what with the olympics and all..... haha
Old Jul 30, 2008 | 06:57 AM
  #78
Mattjin's Avatar
I will take a quick look at 83540008 tomorrow. Post up your stock ROM and current Def with a model and year description for me.
Old Jul 30, 2008 | 09:41 AM
  #79
sub7's Avatar
Here you go... 83540008 is 512k (unlike gta), have most of the address there (with MUT table... perhaps?). Maybe you can get something from it... download
Old Jul 30, 2008 | 10:15 AM
  #80
cossie1's Avatar
Forget that, get 90550001 ripped to bits
Old Jul 30, 2008 | 03:42 PM
  #81
Mattjin's Avatar
hey hey, take a number :-)
I dont have the time to find everything. Just what is obvious and a little useful.
Old Jul 30, 2008 | 03:47 PM
  #82
Mattjin's Avatar
Sub7, is that the stock ROM or a tuned one? Just on first look I can see a few things that look mislabelled. It is difficult for me to verify without the car to test it on but I will check it out over the next day or so and post up what I think would be a correct XML.
Old Jul 30, 2008 | 04:41 PM
  #83
Mattjin's Avatar
Check this out and do some testing. Alot of mislabelled maps. Check the boost limit maps because I am only 50-50 on whether the 2 new ones are correct. The old one I am pretty sure was wrong.
To test the Warmup Ignition map, try zero-ing the maps and see if the car feels better cold.
File Type: zip
Old Jul 30, 2008 | 04:42 PM
  #84
Mattjin's Avatar
This will also be the same. Most likely all Maps labelled as 1 and 2 will be for N,1,2 gear and 3,4,5 gear. But test this before trusting it. Boost maps 2 and 3 will be the same.
Old Jul 30, 2008 | 08:49 PM
  #85
sub7's Avatar
Cool, I'll give it a try. It's easy to spot if lo-timing is hi-timing (or vice-versa). It's a stock rom, un-tuned.
cossie, 90550001 won't work with auto-tranny..
Old Jul 31, 2008 | 12:39 AM
  #86
Mattjin's Avatar
Post up 90550001 stock rom with your current Def and I will see if there is anything obvious.
Old Jul 31, 2008 | 02:27 AM
  #87
cossie1's Avatar
Very true
File Type: zip
Old Jul 31, 2008 | 04:02 AM
  #88
Mattjin's Avatar
Any particular things to find, or just whatever I can spot?
Old Jul 31, 2008 | 04:12 AM
  #89
cossie1's Avatar
Just anything you can spot mate
Old Jul 31, 2008 | 04:45 AM
  #90
Mattjin's Avatar
Got a few for you.
Add the Enrich scaling line from a few posts back.
<table name="Boost Desired Engine Load # 2" address="435c" level="4">
<table name="RPM" address="4d22"/>
</table>
<table name="Boost Desired Engine Load # 3" address="4372" level="4">
</table>
<table name="Max Wastegate Duty # 2" address="431a" level="4">
<table name="RPM" address="5278"/>
</table>
<table name="Max Wastegate Duty # 3" address="4330" level="4">
</table>
<table name="Warmup Ignition Retard 1" address="3e6d" scaling="Enrich">
<table name="Load" address="503a"/>
<table name="Engine Speed" address="500a" elements="19"/>
</table>
