V5, NLTS and the load threshold bug
Old May 27, 2008 | 06:21 AM
TouringBubble's Avatar
I'd test it for you but I never get near 100% throttle on a rev match DS.
Old May 27, 2008 | 10:06 AM
honki24's Avatar
Mine's up on stands at the moment. Sorry.
Old Jun 1, 2008 | 09:09 AM
dudical26's Avatar
Just wanted to bring up a quick question, I don't remember is we have discussed this before or not.
In one of Lucas English's posts he mentions that he switched the NLTS to the bottom clutch switch and he feels this helped his shift times because the NLTS rev limiter goes back to normal faster this way.
So, any ideas about this.
Tephra - would this be possible with coding, rather than having to re-wire stuff?
If it's not possible with coding, how would it need to be done? Any downsides?
I notice in my logs that after letting the clutch out the RPM seems to oscillate a bit after a shift before climbing once again, I can't say for sure if this is a delay due to NLTS but my gut feeling is that it is.
Side note - it would also be good because I know a lot of people run into problems with how SUPER sensitive the top clutch switch is.
Old Jun 1, 2008 | 09:32 AM
sub7's Avatar
It definitely help if we can choose to activate via top or bottom clutch switch (my car dont have top clutch switch) to activate NTLS
Old Jun 1, 2008 | 11:29 AM
JohnBradley's Avatar
On Lucas' car this made a big difference in how fast it comes back into boost because the clutch doesnt have to be fully released before RPM comes back. It is a process to rewire as its not simply moving the switch. Setting it to operate off of either switch would be swell.
Old Jun 1, 2008 | 07:16 PM
dudical26's Avatar
Unfortunately I think I remember Tephra saying the bottom switch does not connect to the ECU, but I hope I'm wrong
Old Jun 1, 2008 | 07:28 PM
tephra's Avatar
hrmm - Not sure.
I will have to find which RAM variable it gets stored in...
mrfred's Avatar
You're correct.
Old Jun 1, 2008 | 07:38 PM
nothere's Avatar
if nlts engages at the bottom of the stroke, doesn't the engine rev to the moon in the mean time?
Old Jun 1, 2008 | 07:42 PM
tephra's Avatar
exactly - or even worse if you dont bottom out it will never cut the revs..
anyways I think the best solution for people having "early engagement" troubles is to "extend" the top clutch switch by putting foam or something on the pedal... that way the pedal can be further down before the ECU thinks its depressed.
Old Jun 1, 2008 | 08:35 PM
Jack_of_Trades's Avatar
I'll see if I can find a replacement switch which has a longer throw for anyone concerned with this. I know I accidentally trip the NLTS all the time when starting a WOT run.
Old Jun 1, 2008 | 10:10 PM
dudical26's Avatar
I have put a bit of foam under my switch which may have helped a bit but it definitely does not give the same effect as running off the bottom switch.
I used to NLTS before the actual ecu mod was out, if you do it really fast the engine only revs up a couple hundred RPM's. I think going of the top or bottom clutch switch is a matter of preference and matter of how fast you shift. If you shift slowly the bottom switch might let the engine rev too high but if you shift really fast the top switch might be too slow to react.
If the bottom switch does not connect to the ECU, is there a way to simply switch the wires from the top and bottom clutch switch or will that present other problems?
Old Jun 1, 2008 | 10:12 PM
dudical26's Avatar
That would be really cool. And we know from the ECU pins that you have an uncanny ability track down hard to find electrical parts.
Old Jun 2, 2008 | 10:53 PM
Lucas English's Avatar
You increase the RPM drop to make up for it but it doesnt rev to the moon if done fast enough.
Old Jun 3, 2008 | 01:21 AM
dudical26's Avatar
good call.
