ecuflash v1.34 help
Old May 25, 2008 | 02:49 PM
Skim003's Avatar
ecuflash v1.34 help
Just got my tactrix cable and tried to download the stock rom from the ecu and get this message from ecuflash.
[17:43:40.005] Using interface OpenPort 1.3b Mitsu TX38CTz*ea5474d55c201133f140013bc5644ce2233741b9
[17:43:40.005] interface close
[17:43:40.014] unable to connect to vehicle interface.
[17:43:40.014] interface close
I could not get v1.29a to work either.
Anyhelp would be very appreciated.
Old May 27, 2008 | 02:07 PM
InfamousTX's Avatar
same problem here
Old May 27, 2008 | 02:24 PM
bboypuertoroc's Avatar
Veteran: Army
Same here. I'm in contact with Tactix right now to try and solve the issue.
Old May 27, 2008 | 02:47 PM
InfamousTX's Avatar
ok. did some diggin. i downloaded ecu unlocker. ran it. then opened ecuflash. it read the rom on my ecu, but now i try to open it and it says unknown rom image!! wtf??
Old May 27, 2008 | 02:53 PM
Veteran: Army
Your's is a different issue if you needed to use ECU Unlocker.
I know damn well my ECU isn't locked, and the cable I had was working with no issues. This problem just popped out of nowhere. I can even still datalog... just can't read or flash ROMs. I can still read/flash using one of my friend's cables though.
OP, can you still datalog?
Old May 27, 2008 | 03:03 PM
InfamousTX's Avatar
i am going to do some datalogging on the way home in an hour or so.
from what i read, seems like an XML file error on my end.
Old May 27, 2008 | 04:03 PM
InfamousTX's Avatar
data logging works fine.
Old May 27, 2008 | 07:10 PM
InfamousTX's Avatar
still getting unknown rom image!!
Old May 27, 2008 | 07:34 PM
boyd494's Avatar
I'm running into exactly the same issue. Did you hear anything back?
Thanks.
Old May 27, 2008 | 07:45 PM
InfamousTX's Avatar
got mine working. copied these into the metadata>evo section
https://www.evolutionm.net/forums/sh...d.php?t=319767
Old May 28, 2008 | 07:01 AM
Skim003's Avatar
I contacted tactrix. They are going to send me a link to fix this problem. I speculating that it's is a issue with the driver.
Old May 28, 2008 | 10:28 AM
Veteran: Army
Can you let me know what that link is when they send it? I haven't heard back from them yet, but it sounds like we have the same problem.
Old May 28, 2008 | 08:16 PM
Skim003's Avatar
Tactrix said that I need to download ecuflash v1.35 for it to work with this cable. So I downloaded ecuflash 1.35 and attempted to install it, but it will not install. Window pops up with "NSIS Error: installer you are trying to use is corrupted or incomplete...etc". Anyone have problem installing ecuflash 1.35?
Old May 28, 2008 | 08:22 PM
Veteran: Army
I just installed it and it installed updated drivers for the cable. I'll give it a shot later tonight and get back to you to let you know if it worked.
Old May 28, 2008 | 10:32 PM
InfamousTX's Avatar
it took me 3 tries to get it installed! but it is up and running with no problems now.
