ecuflash v1.34 help
Old May 29, 2008 | 04:28 AM
Skim003's Avatar
This is weird. I tried downloading in 2 different computers at home and I could not get it to install. I downloaded it at work at it installs fine.
Old May 29, 2008 | 11:17 AM
bboypuertoroc's Avatar
Veteran: Army
OK... I tried to pull my flash from my ECU, and now ECUFlash freezes after I select the option for Evo XI. WTF.
Old May 31, 2008 | 05:44 AM
Skim003's Avatar
I finally got mine to work correctly. Are you still having problems with yours?
Old May 31, 2008 | 10:34 AM
dan l's Avatar
I am having the EXACT same problem with 1.35. I gave up with the ****ing buggy software and went back to tried and true 1.29. I did a complete uninstall (all the taxtrix drivers, ecu flash, the folder in the program files section) then restarted the computer, installed 1.35, restarted again. I did this twice to get 1.35 to work and it did not. When 1.34 came out it did not install on my computer either.
Mind you my computer works fine with 1.29.
Old May 31, 2008 | 11:02 AM
Veteran: Army
Well, I know why it doesn't work... the Evo XI isn't out yet.
But I do have that same issue when I pick Evo IX.
Sure am. How did you fix yours?
I'd go back to 1.29, but then the cable won't work again.
Old Jun 1, 2008 | 02:07 AM
red03evo's Avatar
I'm having the same exact problem and haven't figured it out as of yet.
Old Jun 1, 2008 | 08:21 AM
Skim003's Avatar
If you can't get v1.35 to install on your computer try downloading it from a computer with a different isp. It did not download correctly when I tried it with at home but it downloaded and installed correctly when I downloaded it at work. I think there might be some issues (firewall, connection, etc) with some isp when downloading from openecu.
If it installed correctly but freezes during reflash or ecu read.
1)close ecuflash if opened
2)connect tactrix cable to your computer only (do not connect it to your car)
3)Use the uninstaller and uninstall ecuflash
3)delete the openecu folder from for program files folder.
4)Go to uninstall program from the control panel (there should be 2 drivers for tactrix) uninstall both of those. If you see more than 2 drivers for tactrix uninstall those also.
5)Go to the device manager under system on control and uninstall the device for tactrix cable (it will say openport 1.3 mitsubishi (as serial port) or something similar)
6)unplug tactrix cable from computer
7)restart the computer
8)reinstall ecuflash
Old Jun 1, 2008 | 03:29 PM
red03evo's Avatar
I'll try that, thanks!
Old Jun 1, 2008 | 06:49 PM
RazorLab's Avatar
Same here. I see no advantage to using 1.35 over 1.29, they both do the same thing. Actually, that is wrong, one is buggy and one isn't.
Old Jun 2, 2008 | 03:31 AM
Veteran: Army
Thanks Skim. I'll give it a shot after I get my car back together from powdercoating some engine stuffs.
Old Jul 2, 2008 | 08:44 AM
rodrig.diaz3's Avatar
Ufff thanks Skim003 it really work for me.
regards
BlackHawk_Tsi
Apr 20, 2015 04:25 PM
MonacoGP
Apr 8, 2011 02:06 PM
Hiboost
10
Mar 2, 2011 12:48 AM
napado
13
Mar 31, 2010 01:49 AM
mrfred
Jan 17, 2008 06:48 AM
