Mut Table question.
Old Jun 7, 2008 | 06:52 PM
tnt1106's Avatar
Mut Table question.
I have read everything I can find and still can not get my 0-5v wideband to read via Ecuflash / evo scan. I followed the guide used to describe the LM-1 and have:
Modified my rom to add mut tables.
Running teph's Rear o2 elim mod
Added address of MUT1x colum 2 of 0x8409
Used pin 73 (rear o2 sensor evo ix) for input
added this to my data.xml for evoscan 2.2
<DataListItem DataLog="Y" Color="" Display="Wideband AFR" LogReference="WideBand" RequestID="12" Eval="0.05859*x+7.35" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="22" ChartMin="0" ChartMax="22" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
first by adding that into xml i still cant get it to show on logging menu.
the requestID=12 already shows EGR temp on evoscan 2.2
I have really tried to get this working an help would be much appreciated. Thanks in advance.
I can send my rom and the 2.2 data.xml if it helps.
Edit: Tephra helped me fix, thnks!
File Type: zip
Old Jun 7, 2008 | 07:09 PM
tephra's Avatar
you put the xml in the wrong part of the XML.
Put it near the top, above the ThrottlePostion defintion... about line 30ish..
Old Jun 7, 2008 | 08:36 PM
tnt1106's Avatar
Tephra,
Thank you sooo much! you are the man. I finally got this working. ( I changed to Evoscan version 2.1 and change xml per above), and now it works! Thank again so much!
Now to find out why car won't boost over 8psi suddenly. ( thinking WGA spring or arm messed up.) Growing pains... (first track weekend for us in evo
Old Jun 7, 2008 | 08:49 PM
tephra's Avatar
running wastegate pressure
Old Jun 7, 2008 | 09:04 PM
tnt1106's Avatar
hrmm,
history.
car was stock would boost 19 spike hold 16
added Aem Truboost controller. set it for 18psi almost no spike small taper above 7k
ran this for 2 weeks lots of logging testing worked fine.
came to track at end of warm up lap had 1 spike of 30psi, shut off controller came in looked at car, with controller off only holds 6-8(used to hold 11-12 steady)
unhooked aem, hooked up factory, same thing only 6-8.
unhooked line to WGA, seemed to spike near 20, ill get exact number in morning.
hooked torbo outlet line strait to wga only holds 6-8 (on a 12lb spring right?)
to me sounds like aem malfunctioned maybe, aand wga got messed up somehow, any ideas?
Old Jun 7, 2008 | 09:58 PM
tephra's Avatar
i reckon when you hooked up the factory you connected it wrong.
work out it you are going aftermarket or stock boost control.. if tock get a GM3port and follow the thread on how to hook it up...
mrfred
May 1, 2020 10:16 AM
mrfred
Dec 7, 2015 01:49 PM
upstateEVO
Jan 9, 2012 12:32 PM
mrfred
Dec 2, 2009 02:00 PM
Mattjin
Apr 16, 2009 02:22 PM
