Evoscan Log Order
Old Jun 9, 2008 | 02:46 PM
sponners's Avatar
Evoscan Log Order
Hi guys,
I'm having problems logging IDC (again).
Can anyone put up a post of order of their logs in evoscan (I'm using 2.1)
also I have done the 2byte mod and using 2byte rpm in the calc [InjPulseWidth]*[RPMMUT2Byte]/1200
all numbers are reading 0 though
I'm logging ipw before idc.
does the rpm2byte need to be before idc?
if someone could post up there working log order that would be great!
cheers
Mark.
Old Jun 9, 2008 | 02:51 PM
merkzu's Avatar
Any data items you use in the formula need to be logged first
Old Jun 9, 2008 | 02:55 PM
kreionic's Avatar
Yes 2 byte rpp needs to be above idc
Like merkzu said. Anything that is a calc the item that are calculated need to be above
Old Jun 9, 2008 | 07:53 PM
StreetEvo's Avatar
I'm having the same issue and I'm logging both IPW and 2-byte RPM. All it logs as is 0.
Old Jun 10, 2008 | 04:29 PM
sponners's Avatar
yep sorted!
cheers guys........spot on
Old Jun 10, 2008 | 04:46 PM
kreionic's Avatar
did you put 2 byte rpm in the IDC formula? If you did thats why. Re arrange your order. If you added 2byte rpm to IDC just make sure IPW and 2 byte rpm or regular rpm is above IDC.
Old Jun 10, 2008 | 04:50 PM
StreetEvo's Avatar
Ah, that would probably help if I moved things around a bit lol.
Cbr1000love
Jan 30, 2016 11:57 AM
roni4g63
Nov 14, 2015 11:45 AM
blk-majik
24
Jul 24, 2015 12:10 PM
PeteyTurbo
Jun 25, 2008 02:17 PM
