Evoscan Issue (Ecuflash works)
Old Jun 9, 2008 | 05:08 PM
Done's Avatar
Edit: I reinstalled XP, evoscan just will not stay connected.
I put the openport on com1, and evoscan still will not connect.
I have reinstalled ECUFLASH, and all drivers. I have reinstalled Evoscan, I have also tryed older ecuflash versions. Any ideas?
The evoscan will connect then disconnect right after connecting.
operating system is windows xp.
EVOSCAN error
Info: Initialize Vehicle ECU...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Info: Waiting for INIT Response...
Info: ECU ID: E4C7
Info: Connection successful...
Error: Unable to open COM1
The system cannot find the file specified
any ideas?
Old Jun 9, 2008 | 05:35 PM
cossie1's Avatar
go into the system properties, then device manager, then com ports.
Find the port with the open ecu cable listed, and remove / delete the cable from the system.
Then unplug the cable, and reinsert it.
Hopefully windows will then find the correct driver for it.
Had a similar issue myself a few days ago and the above worked for me.
Old Jun 9, 2008 | 05:46 PM
Done's Avatar
deleted
Old Jun 9, 2008 | 06:48 PM
Done's Avatar
After more investgation, The serial port of the openport is not installing for some reason.
im using mac osx and using parallel to get it to work.
i had it working before, then bought this laptop, and now it wont work.
Old Jun 9, 2008 | 07:31 PM
Done's Avatar
Reinstalled Windows XP, still having same issue.
Evoscan will not open com1, and will not allow me to change it to com 2,3,4.
Old Jun 10, 2008 | 03:21 AM
cossie1's Avatar
Untick wideband.
Old Jan 11, 2009 | 04:13 PM
Kracka's Avatar
Originally Posted by cossie1
Untick wideband.
I did this and it worked, but why? I was having the exact same problem as the original post. Is the LC-1 causing this problem? I seem to be having a lot of issues with that thing.
Old Jan 12, 2009 | 11:00 PM
codgi's Avatar
Untick wideband.
Beat me to it
Old Jan 12, 2009 | 11:01 PM
codgi's Avatar
If your wideband is not connected or EvoScan is not correctly conifgured to the correct COM port for your wideband then you get this error. By unticking it you it no longer tries to connect == no more error.
lolazour
Oct 9, 2016 03:53 PM
kyoo
Feb 25, 2011 05:48 PM
mike86
Jan 20, 2010 07:04 PM
Evo_Matt
Mar 18, 2008 04:36 AM
Thoe99
Oct 11, 2007 12:41 AM
