Tactrix Boost Control Solenoid (Plug-n-Play for Mitsu)
Old Jul 20, 2008 | 06:59 PM
  #46
Pd1's Avatar
Pd1
Originally Posted by justchil
Just to clarify... I hook this unit up and the alt map will switch my boost? The JDM boost sensor is not required (I'm using a GM sensor anyways).
Correct. The JDM MAP is only required if you choose to regulate your boost using the MAP sensor instead of the factory load-based system.
Old Jul 21, 2008 | 04:52 PM
  #47
justchil's Avatar
I'll give it a shot!
I have an old taken apart stock BCS that has the plug intact if someone wants it... I have another complete stock bcs but I'm going to hang on to it for now.
Old Jul 24, 2008 | 02:57 PM
  #48
justchil's Avatar
I got mine today so we shall see how well this thing works. I should be up and running Saturday (I hope)
Old Jul 24, 2008 | 03:05 PM
  #49
justchil's Avatar
OK so would anyone happen to know which nipples go where? There were no instructions so I'm not sure which would be the boost source and which would be the WGA... assuming the metal one is for bleeding.
Old Jul 24, 2008 | 03:17 PM
  #50
RazorLab's Avatar
Old Jul 24, 2008 | 03:28 PM
  #51
justchil's Avatar
HUGE thanks!
Looks like I might need to get a barb for my turbo inlet BUT I've been using MBC's that bleed "open" so I'm going to assume leaving the intake return line open may not cause any problems.
Old Jul 24, 2008 | 06:49 PM
  #52
justchil's Avatar
Here is how I mounted mine... double sided 3m tape with the new magnum vac lines from boostcontroller.com... they are 4mm ID but very thick walled.
Now that I look back... I had probably 5 or 6 plugs I could have used with the GM solenoid. I had to find the stock bcs wires and solder them to the old connector anyways so it really wasn't plug and play for me.
If the performance is nice I'll consider it worth it... I received it from Tatrix.com in 2-3 days
Old Jul 27, 2008 | 02:02 AM
  #53
Steveevo9's Avatar
Hi Justchill,
How has it turned out for you, have you had it turned yet? Nice photo for the set up mate.
Cheers Steve
Old Jul 27, 2008 | 07:39 AM
  #54
justchil's Avatar
I've moved it a little but it's in the same area... My car doesn't run yet but it should in the next few days. I'll let you guys know how it works!
Old Jul 28, 2008 | 12:30 AM
  #55
Steveevo9's Avatar
Good luck with the tune mate. Have you set it up in interupt mode or bleed?
Steve
Old Jul 28, 2008 | 07:53 AM
  #56
fostytou's Avatar
EvoM Community Team
Steve
Looks like interrupt to me.
Old Jul 28, 2008 | 08:21 AM
  #57
justchil's Avatar
^^ I have no clue what you guys are talking about lol. It has a bleed port which is going no where right now... maybe it's a software setting you guys are talking about?
Old Jul 28, 2008 | 09:22 AM
  #58
oldevodude's Avatar
I am interested in the old solenoid as I can use it to make a somewhat cleaner connection to the GM boost solenoid I already purchased. Can you PM me? I will gladly pay shipping.
Thanks
Old Jul 28, 2008 | 10:27 AM
  #59
Jeff_Jeske's Avatar
I'm not sure why you would fear clipping two wires to install the GM 3 port. Its less work than installing a boost gauge. Its also conveniently hidden from view. No one can tell its been clipped.
Old Jul 28, 2008 | 03:35 PM
  #60
oldevodude's Avatar
No fear of clipping simply no desire to clip IF I do not have to.
thanks though
