evoscan/ecuflash noob with question
Old Jun 27, 2008 | 02:59 PM
shuttlegoose's Avatar
6-28-08 EDIT: Alright i might have fixed it. i updated some drivers and things like that and played around a bit. im going to post some links to logs in another post. tell me what you think about my afrs, im not really sure if thats what its supposed to say. let me know.
alright before anybody tells me to search i have been searching for about a week prior to making this post so i could make sure it was nothing i could find out on my own.
i am using ecuflash and also evoscan version .99 as per shameless's suggestion. I have successfully logged (i think) but it did not log, knock, or afr. I have an innovate lc-1 with all the cables needed to connect and things like that. i changed all the com ports and stuff as i found out when i searched which gave me the clear to actually start the log and make sure it didn't give me an error. anyway, for some reason the afrs didnt come through, and knock didn't come through either. also. When i was logging i was expecting to see something more than just what was happening, im used to seeing dsmlink where you could actually see things happening on a steady graph. Also the guages i uploaded weren't really moving either. Also how to i go about looking at the fuel tables and things like that once i can log afrs, or even change the timing maps and things like that. Sorry for the extra newbiness, im trying to get to un-newb status asap so thanks for the help. Any other tricks and tips would be greatly appreciated! thanks again.
Old Jun 27, 2008 | 06:33 PM
sub7's Avatar
Did you download Chris's evoscan xml? Replace that data.xml in your laptop. Do you have serial port on your laptop? And LC1 connected to your serial port?
Old Jun 27, 2008 | 06:59 PM
im not sure, i downloaded his gauges and stuff but i guess i unzipped them improperly or something. yes i have all the cables and serial to usb and things like that connected.
Old Jun 28, 2008 | 12:35 PM
bump for a noob
Old Jun 28, 2008 | 02:33 PM
kstpeter33's Avatar
i thought the lc-1 only worked with the newest version of evoscan? on previous versions it would just have ***In Progress*** or something to that effect
Old Jun 28, 2008 | 07:27 PM
ok here are some logs i took today, let me know what you guys think, especially on the afrs. but chime in whereever
http://uploading.com/files/L8N8BHDZ/1st log AFR 3rdgear.csv.html
http://uploading.com/files/KWJFX7T6/2nd log afr 3rd gear.csv.html
evo jason
Jan 7, 2012 04:25 AM
Tbtalon94
Nov 2, 2010 11:49 AM
al\lupo
May 8, 2008 06:47 AM
NoTec
Jun 18, 2007 10:56 AM
