Ecuflash 1.35 cant reflash
Old Jul 1, 2008 | 07:45 PM
rodrig.diaz3's Avatar
I just install 1.35 ecuflash and i cant reflash
This is the error:
[22:40:38.937] no response to any known code
[22:40:38.937] interface close
[22:40:38.953] interface close
Old Jul 1, 2008 | 08:15 PM
pog0's Avatar
Had this too. Just went back to 1.34.
Old Jul 1, 2008 | 09:18 PM
will try with 1.34
thanks
Old Jul 2, 2008 | 05:31 AM
Still having the same problem, i try the 1.30 , 1.34 and the same error appears.
Any one
Old Jul 2, 2008 | 05:48 AM
TeStUdO's Avatar
Did you uninstall version 1.35 first? Completely uninstall it and then install 1.34.
Old Jul 2, 2008 | 07:10 AM
exactly uninstall 1,35 complete and then reinstall 1.34.
May be the cable is gone ???
Old Jul 2, 2008 | 07:11 AM
TeStUdO's Avatar
Does EvoScan still work? Can you still log?
Old Jul 2, 2008 | 08:46 AM
Finally Works i follow This, thanks to :
Skim003
If it installed correctly but freezes during reflash or ecu read.
1)close ecuflash if opened
2)connect tactrix cable to your computer only (do not connect it to your car)
3)Use the uninstaller and uninstall ecuflash
3)delete the openecu folder from for program files folder.
4)Go to uninstall program from the control panel (there should be 2 drivers for tactrix) uninstall both of those. If you see more than 2 drivers for tactrix uninstall those also.
5)Go to the device manager under system on control and uninstall the device for tactrix cable (it will say openport 1.3 mitsubishi (as serial port) or something similar)
6)unplug tactrix cable from computer
7)restart the computer
8)reinstall ecuflash
Old Jul 2, 2008 | 05:21 PM
mrfred's Avatar
Are you using v1.34 or 1.35 now?
Colby is aware that a few people are having connection problems with v1.35. He hasn't figured out the issue though because so few people appear to be having the problem.
Old Jul 2, 2008 | 10:03 PM
Mr Evolution's Avatar
hopefully I don't get this problem when I try to flash. Just updated to 1.35.
Old Jul 2, 2008 | 10:17 PM
tephra's Avatar
usually its having multiple "tactrix" drivers installed.
uninstall everything - including drivers.
reinstall..
Old Jul 2, 2008 | 10:59 PM
Thanks for the tip Tephra
Old Aug 23, 2008 | 11:11 PM
XBS's Avatar
XBS
I currently have this issue, none of the above worked, any suggestions?
Old Aug 24, 2008 | 06:07 AM
PessimiStick's Avatar
I had to install the cable drivers from 1.29a and use the no lockup patch for 1.35 in order to get it to work.
Old Aug 24, 2008 | 12:24 PM
XBS's Avatar
XBS
I fixed my issue by doing a *complete* uninstall on 1.35, installed 1.34, then used Akitvematrix's ECUunlocker, then I was able to flash the ecu again.
