log boost on uk jdm E8 (with no map sensor)
Old Sep 6, 2009 | 12:12 PM
leecavturbo's Avatar
can i just try the 1.5v battery test on different empty ecu pins until i see an input?
could that casue damage to the ecu tho?
Old Sep 6, 2009 | 12:16 PM
mrfred's Avatar
Originally Posted by leecavturbo
ah but i'm using that pin for lc1 in and that is working using request 3c!
On USDM cars, pin 73 is used for MAP, and pin 74 is a fuel level sensor. Pin 73 should definitely be MUT38 even on your car. Pin 74 can be read on MUT3E. Rear O2 should be pin 75 and can be read on MUT3C. You might want to check your wiring into the ECU.
Old Sep 6, 2009 | 12:44 PM
i'll give 75 a try tomorrow
this is how my ecu is wired and i have checked the n/c do actually mean no cable connected to that pin.
my ecu pinouts
Old Sep 6, 2009 | 01:49 PM
mrfred's Avatar
my ecu pinouts
I've got most of those pinouts from MLR as well. :-) The Evo 5 thru the Evo 8 all seem to have pretty close to the same pinouts. The main differences appear to be sensor inputs being added to later Evos rather than things being moved around.
Old Sep 7, 2009 | 05:18 AM
quite surprised that the spare adac inputs haven't all been found and mapped out for the various ecu types as inputs are a tuners best friend!
i'm having trouble understanding how req 38 and 12 and 3c can relate to 1 single pin input?
Old Sep 7, 2009 | 07:08 AM
mrfred's Avatar
They are well known for the USDM 8 and 9. I'd bet money that the pinout-MUT relationship I mentioned in the earlier post is exactly the same for your ECU/ROM as well.
Old Sep 7, 2009 | 08:16 AM
as you've probably gathered fred the mut stuff is over my head
Old Sep 7, 2009 | 12:14 PM
mrfred's Avatar
Have you had a chance to double-check the LC-1 and MAP sensor wiring into the ECU?
Old Sep 7, 2009 | 12:57 PM
double check it? if you mean to verify the inputs are the correct voltage range and are rising and falling as expected then yes they are correct.
as said lc1 is working correctly and evoscan is reading it with all the scales correct etc on pin 73 and request 3c
"wbo2" was the reference log item
Old Jan 17, 2010 | 09:36 AM
never actually got this sorted.
there is now a USDM rom that will port to jdm (thx ziad)
does that rom have inputs and requests all figured out ? or atleast 2 1 for LC1 and 1 for boost?
Old Jan 18, 2010 | 09:13 AM
wip's Avatar
wip
Lee, did you see my ADC thread on MLR?
evo.matt
Nov 30, 2014 02:23 PM
fast2go
Apr 19, 2012 05:21 AM
racer135
Nov 23, 2009 04:30 PM
mrfred
Aug 14, 2009 07:17 PM
Werd
Jul 31, 2009 04:20 PM
