10 knocks at 2843rpm (stationary)!?????
Old Jul 11, 2008 | 05:34 AM
vaboostn33's Avatar
Originally Posted by evoxsi
shoulda bled the lifters
This would not cause 10 counts of knock.
Old Jul 11, 2008 | 05:35 AM
vaboostn33's Avatar
Originally Posted by joyce1bro
didnt log the car before... i blew my clutch and gearbox a while ago and didnt have acess to a lappy before the breakage. and when i put the car back together i just thought i'd chuck the cams in at the same time....
there was no knock at idle... (is that what you mean by lope)
Have you brought it over the 2800rpms? Does the knock still stay at 10? increase or decrease?
Old Jul 11, 2008 | 05:59 PM
joyce1bro's Avatar
will log today.
Old Jul 12, 2008 | 07:53 AM
Slo_crx1's Avatar
It might because this sounds like more of a mechanical issue dealing with phantom knock. Under normal circumstances I would say it's phantom, but since this guy is saying he flashed some generic-type map with cams and lifters that weren't bled, it's very possible it's real knock and he should've tried removing timing first before posting his problem here.
Old Jul 12, 2008 | 08:07 PM
joyce1bro's Avatar
thanks
Old Jul 13, 2008 | 06:46 PM
joyce1bro's Avatar
ok a friend and i were just having a general look around the engine bay today and found that there was a big crack between my header pipes and the flange to the engine..... i started the car and at idle could hear an exhaust leek and even see the gas's coming out...
i read on another post that this might be the poss cause of knock..... is this correct????
also is it safe to drive the car around with the new cams installed without a tune??? i just fitted a new clutch so i want to run it in before i tune it... as long as i dont boost and just baby it that should be ok????
suggestions please
