Rom routines - Tephra Mfred etc etc
Old Jul 16, 2008 | 03:31 PM
bondango's Avatar
How hard would it be to insert a Routine into the 90550001 so that Stat_limit functions, would it be as simple as adding in some extra coding
IF vehicle_speed>0 AND vehicle_speed<3 AND rpm>=stat_limit THEN revlimit_routine
As the Stat limit dont work on any of the E7 Roms, so the coding must not actually be there.
Ps this comes from my psuedocode days and BASIC lol
Old Jul 17, 2008 | 04:45 AM
tephra's Avatar
yeah - it's planned for a future release of 90550001...
Old Jul 17, 2008 | 10:57 AM
JoeBee's Avatar
By the way, can anybody tell us EVO 7 owners how the stationary limit will be done?
Is there a fuel cut and/or an ignition cut? If it is not so hard to code then maybe I can implement it in a 7 ROM.
Old Jul 17, 2008 | 12:36 PM
jcsbanks's Avatar
Change the pointer to the RPM limiter to RAM. Update the RAM variable depending on speed.
Old Jul 20, 2008 | 07:42 AM
JoeBee's Avatar
Many thanks. A simple but very good idea.
Dammed most of the times I think to complicated.
Old Jul 26, 2008 | 03:22 AM
JoeBee's Avatar
Stationary Rev Limiter on EVO VII, 99860002... done!
This way:
If Vehicle Speed <= 16km/h then revlimit = 5000
else revlimit = 7606
Old Jul 26, 2008 | 06:34 AM
jcsbanks's Avatar
Nice.
Old Jul 26, 2008 | 08:53 AM
cossie1's Avatar
Ohhh, can you get this into the 90550001 rom now ???
Old Jul 26, 2008 | 08:55 AM
tephra's Avatar
already in progress
5.8 will be a special for 90550001
ill get it out this week...
Old Jul 26, 2008 | 10:10 AM
cossie1's Avatar
Good news tephra
Can't wait
Old Jul 26, 2008 | 10:54 PM
codgi's Avatar
This way:
Why 16km/h? Are you hard setting revlimit to be 7606? Or are you setting to be whatever the ram value for the regular rev limit already is?
Old Jul 27, 2008 | 03:27 AM
sub7's Avatar
Originally Posted by tephra
already in progress
will donate again for your effort. Hope it'll include ecu boost control with GM/Haltech boost solenoid
Old Jul 27, 2008 | 03:34 AM
dolphin888's Avatar
Can someone upload 90550001 V5 again?? in globalshare.net it's unavailable for download
Old Jul 27, 2008 | 03:50 AM
jcsbanks's Avatar
Because of the load-store architecture of the SH2 every variable longer than a byte loaded into a restricted register set has to be read from ROM or RAM. Even a "hard" setting would really be soft if you just updated the address of the rev limit in Ecuflash, although I would think he wouldn't have moved it.
Presumably 16km/h to account for wheelspin on launch but to make sure the rev limiter resets to 7606 by the time you're at the top of first gear.
Old Jul 27, 2008 | 07:22 AM
JoeBee's Avatar
Yes.
If speed <= 16km/h use the value at address xx (new created position)
else use the value at address "normal ref limit"
The 16 (8 in the raw variable of vehicle speed) is hardcoded right now, but can be changed to "adjutable" quite easy.
If tephra timeline is like evoscan's timeline , then you can send me your rom with your xml file than I can patch it. But if he is ready next week it may be a waste of time.
(Send me a PM then I give you my email. Some of my email accounts was checked rare.)
Why 16? During dissasembly I have found somewhere in the code this value for vehicle speed (8 in raw). This value has been burned into my brain so I must use it.
...and I was sure that this is a small value that the ecu can processing without testing it.
