Rom routines - Tephra Mfred etc etc
Old Jul 27, 2008 | 12:48 PM
codgi's Avatar
Originally Posted by jcsbanks
Because of the load-store architecture of the SH2 every variable longer than a byte loaded into a restricted register set has to be read from ROM or RAM. Even a "hard" setting would really be soft if you just updated the address of the rev limit in Ecuflash, although I would think he wouldn't have moved it.
Presumably 16km/h to account for wheelspin on launch but to make sure the rev limiter resets to 7606 by the time you're at the top of first gear.
That's what I am banking on and he later confirmed...much nicer than a hard setting
Old Jul 27, 2008 | 12:50 PM
codgi's Avatar
Originally Posted by JoeBee
Yes.
If speed <= 16km/h use the value at address xx (new created position)
else use the value at address "normal ref limit"
The 16 (8 in the raw variable of vehicle speed) is hardcoded right now, but can be changed to "adjutable" quite easy.
If tephra timeline is like evoscan's timeline , then you can send me your rom with your xml file than I can patch it. But if he is ready next week it may be a waste of time.
(Send me a PM then I give you my email. Some of my email accounts was checked rare.)
Why 16? During dissasembly I have found somewhere in the code this value for vehicle speed (8 in raw). This value has been burned into my brain so I must use it.
...and I was sure that this is a small value that the ecu can processing without testing it.
Oh I don't need it...was just curious to the logic behind it. I have a regular boring old '05 VIII .
Old Jul 27, 2008 | 02:10 PM
jcsbanks's Avatar
Even if he did move it you could move it back by changing the address he uses to look it up - wouldn't even need to touch the assembly. My point is that very little is hardcoded on the SH2 because of its architecture. Very rarely would you have an op code and a constant rolled into the instruction, even then it would usually be 8 bits into R0.
Old Jul 29, 2008 | 02:43 AM
JoeBee's Avatar
Today I have take a look on the 90550001 V5 Disassembly.
The problem with the rev limiter is, that tephra has already used it (and modify it) for his patches.
This means that it will be much more work, because I must edit tephra's code and cannot use my code to edit the OEM Address.
@tephra
Is your 5.8 for the 90550001 ready in time?
Old Jul 29, 2008 | 03:50 AM
tephra's Avatar
yeah it will be done tomorrow hopefully..
Old Jul 29, 2008 | 04:25 AM
cossie1's Avatar
Looking forward to it Tephra.
@JoeBee, Thanks for looking into it for everyone with 90550001.
You have got alot further than any of us that were looking at it a while back could, as none of use could even disassemble it propperly
Old Jul 29, 2008 | 04:46 AM
BarryC's Avatar
Originally Posted by tephra
already in progress
5.8 will be a special for 90550001
ill get it out this week...
good stuff Dave
and antilag for v6.0
Old Jul 29, 2008 | 04:48 AM
tephra's Avatar
Not sure on V6 yet.
probably be a whlie away unless i get motivated
Old Jul 29, 2008 | 04:52 AM
cossie1's Avatar
Get motivated then
Old Jul 29, 2008 | 02:26 PM
bondango's Avatar
A paypal is in Order then! thanks dave
V6 with Antilag sounds Promising lol
Old Jul 29, 2008 | 06:37 PM
sub7's Avatar
90550001
Old Jul 30, 2008 | 10:49 AM
dolphin888's Avatar
I mean it:
Old Jul 30, 2008 | 02:29 PM
cossie1's Avatar
Originally Posted by dolphin888
I mean it:
Old Jul 30, 2008 | 07:55 PM
tephra's Avatar
Well I guess we can't call you racist - because its a black AND white dog.
lol..
ill try and get 5.9 out today - but work is killing me atm... wish me luck
Old Jul 31, 2008 | 08:43 AM
dolphin888's Avatar
Any news about V5.9 90550001? Maybe someone could post again V5 then?
tephra
Aug 1, 2018 01:02 AM
buckmarley
Feb 9, 2016 05:03 PM
danfalcas
Sep 30, 2015 08:25 PM
EvocentriK
Aug 3, 2013 06:07 AM
David Buschur
Jun 25, 2010 10:01 AM
