roms and tephra patch
Old Jul 19, 2008 | 11:54 AM
tephra's Avatar
did u have autovalet enabled?
turn of the valet mode other wise your car wont start
Old Jul 19, 2008 | 12:02 PM
Big~D's Avatar
Hi Lee,
Be interested to see if you get this working as I've been waiting for it too.
Keep us posted.
Old Jul 19, 2008 | 12:04 PM
leecavturbo's Avatar
edit. it was enabled, goes to retry
Old Jul 19, 2008 | 12:14 PM
valet off = no start still?
Old Jul 19, 2008 | 12:15 PM
tephra's Avatar
autovalet off?
what flashing is it doing?
does it turn over, and just not start?
Old Jul 19, 2008 | 12:22 PM
tephra's Avatar
failing that post up a picture of your tephramods in ecuflash so i can see your settings...
edit- going to bed, its 5:30am..
Old Jul 19, 2008 | 01:15 PM
night night lol
yes it turns over, the cel flashes fast for 5secs then a very brief pause then flashes again for 5secs then goes off
for breakfast
Old Jul 19, 2008 | 08:33 PM
tephra's Avatar
hrmm....
what did u do with the immobiliser code?
Old Jul 19, 2008 | 10:29 PM
hrmm....
i copied it from my stock rom to the 96530006.
i did not make any xml changes to do with immobiliser!
however when i copied your mods from 5.1xml and pasted them into
the 96530006 xml some of the text was not aligned with the majority of it
so i tabbed the ones that wasn't aligned!
Old Jul 20, 2008 | 04:34 AM
tephra's Avatar
ok - can u try disabling the immobiliser, one of the FAA/FCA bits I think... look in the other thread...
Old Jul 20, 2008 | 06:55 AM
Evo8uk's Avatar
FAA is the one. on your stock rom it will be 56D8 but to switch off the immobilser it needs to be changed to 56D0.
Old Jul 20, 2008 | 08:55 AM
in the xml file? or the hex value in the rom / ecuflash?
Old Jul 20, 2008 | 10:36 AM
Evo8uk's Avatar
Add this line into the xml file you wish to use <table name="(periphery 0)" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
and then change the value to 56d0 which is no immobilser and no rear o2 the stock hex is 56d8 which is no rear o2 as we dont have rear o2 sensors on the jdm cars.
Old Jul 20, 2008 | 12:54 PM
made the xml change.
opened the rom and the hex values will not change, yes i clicked set data or equals button a box pops up you press enter after entering your value.
but the hex does not show a change?
Old Jul 20, 2008 | 01:23 PM
RazorLab's Avatar
You need to input hex changes as 0x56DA, always input the 0x before whatever hex change you are doing
