roms and tephra patch
Old Jul 20, 2008 | 01:51 PM
  #31
leecavturbo's Avatar
Originally Posted by razorlab
You need to input hex changes as 0x56DA, always input the 0x before whatever hex change you are doing
ok that worked but still no start
just something i noticed.
with my stock rom the order of maps is
rom info
misc
mods
fuel
timing
limits
turbo
idle
etc
but with v5.1 9653006
misc was half way down with fuel and timing moved to different places too!
does that matter?
Old Jul 20, 2008 | 02:02 PM
  #32
RazorLab's Avatar
Turn off valet and move the valet RPM limit to like 8k and see if it starts up then
Old Jul 20, 2008 | 02:07 PM
  #33
valet was/is off! rpm was 1400rpm.
my settings are on post #22
Old Jul 20, 2008 | 02:09 PM
  #34
RazorLab's Avatar
try the valet rpm at 8000.
Old Jul 20, 2008 | 02:15 PM
  #35
ok will be tomorrow now
Old Jul 20, 2008 | 04:21 PM
  #36
tephra's Avatar
hrmmm... something else mustn't be right... can u post your ROM so we can take a look? maybe the injector scaling is off or something...
Old Jul 20, 2008 | 05:14 PM
  #37
just to note with my stock rom uploaded when i turn on ignition my cel is on steady for 10secs ish,
but with 96530006 v5.1 when i turn on igntion my cel flashes for 10secs ish,
my stock rom 2003 evo 8 jdm 93660005
http://www.keepandshare.com/doc/view.php?id=701576&da=y
below is 96350006 v5.1 with all my fuel , timing, idle, scaling tables from my stock rom 93660005 copy and pasted.
Old Jul 20, 2008 | 05:27 PM
  #38
tephra's Avatar
fast or slow flashing?
that sounds like valet mode is enabled.
Old Jul 20, 2008 | 05:28 PM
  #39
fast
Old Jul 22, 2008 | 09:57 AM
  #40
tephra did you have a quick look at my roms / starting issue ?
Old Jul 22, 2008 | 06:32 PM
  #41
tephra's Avatar
not yet - will do today.
but fast flashing indicates you have valet turned on.
but you do have a 1400rpm limit, so it should start ok.
ill let u know!
Old Jul 27, 2008 | 04:58 AM
  #42
anything look wrong?
Old Jul 27, 2008 | 06:12 AM
  #43
tephra's Avatar
sorry man - tomorrow I promise
Old Jul 27, 2008 | 10:50 AM
  #44
silver_evo's Avatar
WOAH! i just found this thread, those rom patches are amazing! Flash cel on knock, and all the other good functions! Great work tephra. I just have one question... Would this rom patch work on a 03 USDM VIII (94170008)? If not, should i install my copy of IDA-Pro and start dis-assembling my rom?
EDIT: Nevermind, i found it on your V5.8 testing thread. I can use 94170015 i believe. YOU ROCK!!!!
Old Jul 27, 2008 | 04:04 PM
  #45
tephra's Avatar
Correcto (on both accounts :P hehe)
