Can anyone confirm that EVO X MAP sensor is same as JDM MAP?
Old Jul 31, 2008 | 08:26 AM
dudical26's Avatar
Can anyone confirm this? I want to buy a MAP sensor but want to make sure they are the same item?
Thanks
Old Jul 31, 2008 | 08:33 AM
dolphin888's Avatar
Do you have part number?? Let me know, if you do.
Old Jul 31, 2008 | 08:41 AM
Mike01gsr's Avatar
I talked to Russell from Mitsubishiparts.net and he said they are the same and he has sold quiet a few already. I made a post under his vendor section. It goes for about 148 shipped and has them in stock!
Old Jul 31, 2008 | 09:06 AM
dudical26's Avatar
yea that is the price I found also. I am about to get one becuase I really dont feel like waiting to get one from Japan.
I just want to make sure they have the same part number or someone has acutally logged using one.
Old Jul 31, 2008 | 09:16 AM
daisaw1219's Avatar
i want to know if you can use the regular evo ix sensir in the evo x....I want to swap out with my cousin to check things out
Old Jul 31, 2008 | 09:46 AM
travman's Avatar
yes they are the same - i run one and have been for a few months now.......my gf bought me one from JNZ tuning, i had a surprise box arrive at my work.
Old Jul 31, 2008 | 09:52 AM
dudical26's Avatar
Definitely not. The Evo X/JDM MAP sensor is a 3bar sensor and the calibration is very different. If you swap your sensor into his car, I have no doubt that his car will get a CEL and might not run right.
Old Jul 31, 2008 | 09:55 AM
chrisw's Avatar
no the EVO IX map sensor will not work in the X. The X map sensor will work in the IX, but you have to reprogram the ECU.
Old Jul 31, 2008 | 10:12 PM
sub7's Avatar
I think with Evo X map sensor on Evo IX, they just need to re-calibrate from ecu? Which field in the xml can be use for calibration?
edit: sorry, I think barometric is used to calibrate
Old Aug 1, 2008 | 09:40 AM
cpoku's Avatar
Worksevo
Try WORKSEVO in cali, i got mine $126 and some change shipped, i just need to know how to set it up in my car so i can stop having a extremely rough idle(if i dont give it gas car will cut)
Old Aug 1, 2008 | 09:56 AM
travman's Avatar
uh so you just installed it and changed nothing else??
did you miss this thread?
https://www.evolutionm.net/forums/sh...hlight=jdm+map
Old Aug 1, 2008 | 09:57 AM
travman's Avatar
No you just need to follow the directions Mrfred so kindly laid out for everyone.....the evo X map sensor is the exact same part number as the jdm 3 bar.
Old Aug 1, 2008 | 11:32 AM
cpoku's Avatar
i changed it to spec on mrfred's thread and was having bad idle problems, sometimes the idle would drop so far, the car would shut off; i switch it back to stock flash, idle would just go up and down and would not stabilize but it wouldnt shut off
scheides's Avatar
EvoM Moderator
Yes, I have been using the X sensor for several months now, love it!
Old Aug 1, 2008 | 11:40 AM
travman's Avatar
U changed the scalings as well? i had a idle issue but i missed the scaling changes and just entered the new values....
pays to triple check after your double check.
