A/F at idle is WAY lean
Old Aug 3, 2008 | 01:08 PM
jmtx86's Avatar
I just bought the car and at idle the car is WAY lean, Right now im just running a stock map with the injector size bumped. I haven't change the injector battery voltage latency. Is that maybe my problem?
I have precision 850cc installed in the car at the moment with hks 280's. When ever I give the car a little rev and the rpm drop after, the car just dies on me.
Can someone offer me a little help?
Old Aug 3, 2008 | 04:18 PM
tephra's Avatar
what are your fuel trims saying?
Old Aug 3, 2008 | 04:42 PM
jmtx86's Avatar
im going to buy logging software tomorrow, im just trying to get it right tonight, but i guess im going to have to wait it out.
Old Aug 4, 2008 | 07:35 AM
justboosted02's Avatar
search the forum for injector scaling, there are some good instructions on how to do it. just using the scaling number is not enough
Old Aug 4, 2008 | 12:08 PM
G20's Avatar
G20
how did you know it's too lean?
Old Aug 4, 2008 | 12:13 PM
srcevo8's Avatar
If you give it some gas before the car dies, can you keep the car running? Or does it really want to die at that point and is unrecoverable? If you can save it then it sounds fairly normal for cams.
Old Sep 20, 2008 | 06:32 AM
jmtx86's Avatar
AEM WB
I can save it but it wants to die, I have HKS 280 so that might be it.
Also when I drive the car and give it 25% throttle it leans way out and the car sputters and I have the map extremely rich. Im going to TRY to scale the injectors today and see what happens.
Old Sep 20, 2008 | 09:40 AM
RazorLab's Avatar
If the car has larger injectors and the latency table isn't tuned for them, that is your issue.
I am sure the fuel trims are all out of wack.
Old Sep 20, 2008 | 07:03 PM
Jack_of_Trades's Avatar
Lemme guess, you have 850cc injectors and scaled them with a value of 850 right? Try a value of 780cc and that should get you more in the ballpark for the moment.
Old Sep 20, 2008 | 11:13 PM
jmtx86's Avatar
Nope I have them scale lower then that. I need someone to tune my car i think
Old Sep 21, 2008 | 12:26 AM
tephra's Avatar
what are your fuel trims telling you?
Old Sep 21, 2008 | 09:25 AM
jmtx86's Avatar
I have fuel trim Low, Middle, High. Which should I be looking at? I got the car to Idle better but my AF goes from like 14.7-15.1-16.0- then Back up, HKS 280's causing this?
This is the first car im tuning, I just want to get it so I can have some fun (wot runs) and not have to worry about blowing it up until I can get to my tuner.
Old Sep 21, 2008 | 04:15 PM
tephra's Avatar
add these to your evoscan data.xml (near the current fuel trims will do)
Code:
        <DataListItem DataLog="N" Color="" Display="Fuel Trim Idle" LogReference="FuelTrim_Idle" RequestID="0C" Eval="(0.1961*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-255" GaugeMax="255" ChartMin="-255" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Fuel Trim Cruise" LogReference="FuelTrim_Cruise" RequestID="0D" Eval="(0.1961*x)-25" MetricEval="" MetricUnit="" Unit="%" ResponseBytes="1" GaugeMin="-255" GaugeMax="255" ChartMin="-255" ChartMax="255" ScalingFactor="1" Notes="Measured voltage from the car battery. May be as low as 10 Volts when ignition is off. Should rise to around 14-15 Volts when the engine is running." Priority="1" Visible="False" />
Then you can log Idle+Cruise...
Old Sep 21, 2008 | 05:14 PM
mnbvcxz's Avatar
im having the same problems!!!i cant figure it out. did a boost leak test, checked for exhaust leaks, switched front o2 sensors. car drives fine. but the idle sucks! it throws the p0300 code every single time at idle. a/f goes from 14.7 and drops to 18.0.
Ozmi007
Nov 15, 2016 12:32 PM
onefast2gdsm
May 1, 2016 12:23 AM
Siluck2
11
Apr 11, 2016 06:06 PM
mrm95
Nov 7, 2014 01:04 PM
mrm95
Nov 1, 2014 09:30 AM
