evo swapped 1g dsm issues with tephra v7 sd
I just swapped a 03 lancer ecu in my 1g dsm flashed with tephramods v7 with 3d ve table sd. I have pte 1200 injectors and theyre scaled.
Im having issues with the car revving to 4k with the stock ve table. If i lower the ve in the idle cells the car idle surges from 1k to 1500 rpm. Cruising is lean 16:1 but its smooth.
I adjusted the ignition timing
I adjusted the tps as it was way off
No boost leaks
Changed the map scaling to 1:1 and set it to a gm3bar
I messed with the isc tables a little bit but didnt really notice a change.
Anyone have any ideas of what would cause this? And ia there a "simple" way of building the ve table? I have a 2g maf but dont really want to go through the hassle of changing my setup to run it.
The mods on the csr are:
Hks 272 regrinds
Holset hx35
Pte 1200 injectors
Gm 3 bar
Gm iat sensor
Punishment fmic
03 lancer ecu flashed with tephra v7 sd
Afpr
300lph pump
Etc
No boost leaks
Hks 272 regrinds
Holset hx35
Pte 1200 injectors
Gm 3 bar
Gm iat sensor
Punishment fmic
Afpr
300lph pump
Etc
CT9A PR
Apr 27, 2020 11:53 PM
tsi20gawd
Mar 17, 2014 09:40 PM
