Stock Evo 9 IDC's
Old Aug 7, 2008 | 02:23 PM
RazorLab's Avatar
I personally think evoscan has about a 10% buffer. I usually don't see loss of fuel control until I see 110% IDC's logged.
Old Aug 7, 2008 | 04:04 PM
mrfred's Avatar
Its not EvoScan. The buffer seems to be in the raw value in the ROM.
Old Aug 7, 2008 | 04:26 PM
tephra's Avatar
isn't it just due to the fact we are always underscaling the injectors?
ie 513 for 560's... etc etc
anyways 110 is the real 100 :P
Old Aug 7, 2008 | 10:51 PM
RazorLab's Avatar
I just recently started having some breakup right at peak boost after upping my boost from 28 to 30psi. But not all the time. I am beginning to think my stock coils are getting weak or something from all the hell I have put them through, or I have a boost leak
Well, I figured out why I was getting breakup. Turns out my BOV was leaking pretty bad. I called on the old school DSMer in me and crushed my BOV today.
First run out the car hit 33psi, and that was with error correction kicking in and yanking 10% wgdc.
Was leaking just a bit.
It also fixed my rich dip in AFR at peak boost that has been plaguing me.
Nice, two birds with one stone.
Old Aug 7, 2008 | 11:10 PM
tephra's Avatar
crushed your bov?
just added preload to the spring or something?
Old Aug 7, 2008 | 11:33 PM
RazorLab's Avatar
Originally Posted by tephra
crushed your bov?
Yup. Old DSMer trick.
Old Aug 8, 2008 | 05:59 AM
scheides's Avatar
EvoM Moderator
IX/MR bov? Let me know if you notice any extra bucking on the highway on long uphill stretches, i.e. the same issues Forge and other aftermarket bov's exhibit (flutter). I'm thinking about doing this too.
Old Aug 8, 2008 | 06:20 AM
dudical26's Avatar
I have crushed mine and I do notice more flutter. If I'm in 4th going up a hill at light throttle and I let off the car will buck bad. I have learned not to come of the throttle slowly but rather to realease all at once - stopps the bucking.
razor - I am supprised a leaking BOV would cause breakup. I can understand the rich condition at peak boost but why breakup?
Old Aug 8, 2008 | 07:34 AM
fostytou's Avatar
EvoM Community Team
It always amazed me how "safe to the point of unsafe" they do this stuff from the factory.
I thought there was some reason people were avoiding crushing the IX/JDM valves. There is also the stopleak kit that puts a nipple near the bottom of the valve to help it hold... that might fix your problem with less surge/bucking.
I was worried about my stock SE BOV leaking now that I'm starting to tune E85. I opted to go the Synapse route, and its not nearly as big as I thought. I'll let you know how it works after installing it this weekend.
Old Aug 8, 2008 | 12:38 PM
RazorLab's Avatar
Yes I went out and tested it last night. If I put some load on the car and pull about 2psi or so and lightly let off the car surges a bit, not like a forge does however.
I crushed mine a bit aggressive. I crushed it until the nipple hit the ridge. I would imagine half of that might do the trick as well.
Old Aug 8, 2008 | 01:09 PM
dudical26's Avatar
I really want to see how that synapse performs...keep us up to date on it.
Old Aug 8, 2008 | 07:39 PM
mrfred's Avatar
+1
Old Aug 8, 2008 | 10:41 PM
Jack_of_Trades's Avatar
I bench tested 2 of the Greddy Typr-RS bov's and they leak at 29-30psi with only the lighter of the two springs. Keeping both springs in causes insane compressor surge. ITs a 50 or 55mm valve I think, I need to find a BOV with a larger valve but holds up to 35psi, to help with any surging.
Old Aug 9, 2008 | 03:23 PM
PeteyTurbo's Avatar
I think my bov is leaking past 25psi (jdm evo)..Whenever I go past 25psi now the intake/bov makes a surging sound like it is opening and closing rapidly but not to the point of the car actually shaking, goes away when I turn the boost down..I'll probably crush mine a bit and see if it helps, otherwise I may go with the synapse.
Old Aug 9, 2008 | 04:39 PM
Yup, thats a leaking BOV alright.
