car stalls with a/c on
Old Jul 30, 2009 | 09:29 PM
  #46
D-VO's Avatar
Originally Posted by Appauldd
I forgot all about this thread.
I have my AC issue completly resolved. Below is the things I did to cure it. Yes it is a lot.
Adjusted idle error tables to start with 0 and go up to 8
Raised idle stability timing control sensitivity to 150
Hi Paul, finally a solution to my problem! I haven't tried it out yet, but I wanted to know where are these two tables found?
"idle error tables "
"idle stability timing control sensitivity "
Thanks a lot!
Old Jul 31, 2009 | 04:58 AM
  #47
Appauldd's Avatar
These are for the 94170015 ROM
<table name="Idle Error - Normal" category="Idle" address="434a" type="2D" level="2" scaling="ISCVSteps">
<table name="Idle Error" address="647e" type="X Axis" elements="9" scaling="RPM"/>
</table>
<table name="Idle Error - A/C On" category="Idle" address="435a" type="2D" level="2" scaling="ISCVSteps">
</table>
<table name="Idle Stability Timing Control" category="Timing" address="174e" type="2D" level="2" scaling="uint16">
<table name="Settings" type="Static X Axis" elements="3">
<data>Sensitivity</data>
<data>Timing Limit</data>
<data>Untested</data>
</table>
</table>
Old Jul 31, 2009 | 03:07 PM
  #48
LeXcite's Avatar
Have u tables for TephaMod v7t6?
Old Jul 31, 2009 | 03:17 PM
  #49
Asmodeus6's Avatar
I had mundo idle issues on this rom coming from 96940011... with idle and AC.
Where I never did before.
Then my AC pump locked up last week. So I just removed AC. Car has never run better.
(41k on the car.)
Old Jul 31, 2009 | 04:17 PM
  #50
LeXcite's Avatar
Great solution for not having AC issues ... )))
Old Jul 31, 2009 | 08:26 PM
  #51
D-VO's Avatar
</table>
</table>
</table>
</table>
Would you happen to know where I can get the definitions for these tables on the 96940011 ecu?
Old Aug 2, 2009 | 01:54 PM
  #52
Appauldd's Avatar
I wish i did...But since you have an VIII you should be able to convert over to the 94170015 ROM rather easily. If you decide to give it a shot....I can hook you up with my ROM in stock form. I have every patch, fix, and finding to date.
Paul
Old Aug 2, 2009 | 09:23 PM
  #53
D-VO's Avatar
Paul
Isnt that an 03 rom? I thought the rom had to come from a car that has the acd for it to work properly.
Old Aug 2, 2009 | 09:32 PM
  #54
YzBrad99's Avatar
My car has been doing this for about a year now....its soo annoying. I have the Cosworth M2's also. Which one of these methods work the best?
Old Aug 2, 2009 | 09:35 PM
  #55
D-VO's Avatar
I like appauledd's method, my car has been staying on with the A/C in use for longer than it ever has. The only thing is I need the "idle error" tables ported over.
Old Aug 2, 2009 | 09:59 PM
  #56
D-VO's Avatar
Hey Paul. Is this what the tables are supposed to look like before they're corrected?
Thanks
Old Aug 2, 2009 | 10:32 PM
  #57
Appauldd's Avatar
These are mine. Keep in mind I have the stability raised and have done timing adjustments too.
The picture is a little blurry....
Idle Error AC ON ....0, 1, 2, 3, 4, 5, 6, 7, 8
Idle Error Normal....0, 1, 2, 3, 4, 5, 5, 5, 5
Stability control.... 150, 8, 8
Old Aug 2, 2009 | 10:40 PM
  #58
Appauldd's Avatar
You are correct about the ROM..... I didn't realize you have ACD.
You can try the universal ROM 96530006. It is supposed to work on all VIIIs.
I tested it on an 05 VIII .....didn't work for me. Worth a shot though.
Old Aug 2, 2009 | 10:50 PM
  #59
Appauldd's Avatar
Stock values
Stability 128, 8, 8
Idle error(s) 0, 1, 2, 3, 4, 4, 4, 4, 4
Old Aug 2, 2009 | 11:15 PM
  #60
D-VO's Avatar
I forgot to ask, where did you get your definitions from? Was it on here? I can't find anything on the idle error tables.
