TephraMOD V5.10
Old Jan 9, 2009 | 04:44 AM
  #766
Evoryder's Avatar
Any luck for those with phantom knock from this patch? It's very strange. I gotta get a log to see if it's the "cel flash feature going off" or "real knock" ...I get it at very low TPS % at a slight ramp to lets say 30-40% tps..
Old Jan 9, 2009 | 06:45 AM
  #767
Evo8uk's Avatar
Originally Posted by grayw
Tephra, Changing MUT 41 to 0x840B on 96260009 is still not making 1 byte load log in Evoscan, any idea?
Changing my MUT41 to 0x840B worked perfectly
Old Jan 9, 2009 | 01:26 PM
  #768
grayw's Avatar
Sorry D my mistake, works fine
Originally Posted by tephra
HRMM
knowing me its probably another fracking bug in that rom (bane of my existance that romid :P)
can you just check its MUT41, requestid=41 in evoscan and dbl check the factor = 1.2 for both rom and evoscan?
do you get any log?
Old Jan 9, 2009 | 04:01 PM
  #769
lan_evo_mr9's Avatar
When you say delete xml, are you talking about the base and rom?
Old Jan 9, 2009 | 05:01 PM
  #770
never mind- sorry
Old Jan 9, 2009 | 05:30 PM
  #771
MR Turco's Avatar
Can someone tell me what ROMs are for a 2005 evo 8? I have to load this on a kids car tomorrow but he nor i will know the rom # until i get there. Just looking to get an idea before i get there.
Old Jan 9, 2009 | 05:33 PM
  #772
tephra's Avatar
most likely 96940011, in which case you will need to load 95630006 over the top...
u can keep the immob - just look at the other thread for info on what todo
Old Jan 9, 2009 | 05:43 PM
  #773
MR Turco's Avatar
Thanks David! Which other thread are you talking about?
Old Jan 9, 2009 | 05:55 PM
  #774
tephra's Avatar
um something like 96530006 WORKS for 96940011...
Old Jan 9, 2009 | 06:10 PM
  #775
MR Turco's Avatar
Found it: https://www.evolutionm.net/forums/ec...9694011-a.html
I didn't realize you were behind that either. Great work as always.
Old Jan 9, 2009 | 06:19 PM
  #776
tephra's Avatar
yeah thats the one, last couple of pages has the immob fixup in it
Old Jan 9, 2009 | 06:34 PM
  #777
MR Turco's Avatar
Yup i grabbed the periphery 7 table from there.
Old Jan 14, 2009 | 08:05 PM
  #778
laramie_05MR's Avatar
partially confirmed 96420011 works for an 04 USDM RS. Tested NLTS, CEL and Valet. Untested Alt Maps.
Old Jan 14, 2009 | 08:44 PM
  #779
Lancerguy'03's Avatar
Originally Posted by laramie_05MR
partially confirmed 96420011 works for an 05 USDM RS. Tested NLTS, CEL and Valet. Untested Alt Maps.
its a 2004 USDM RS.....and it seems to be working good....and havent done the alt maps yet. my old ROM ID was 96420008 and switched to 96420011.
edit: and the NLTS is ****in badass!
Old Jan 14, 2009 | 09:07 PM
  #780
Sorry Andrew 04 RS
