disable o2, Version 1.35.1650?????
Old Aug 10, 2008 | 04:45 PM
EatSleepBoost's Avatar
i have searched on this site and can't find out how to disable the rear o2 using this version. it says go to the misc section on the version 1.3 however the 1.35 i don't see it. can somebody send me a link or give me a quick paragraph on how to do it. i am experienced using ecu flash so any help would be apreciated.
Old Aug 10, 2008 | 06:25 PM
silver9mr's Avatar
bump id like to know too
Old Aug 10, 2008 | 06:41 PM
Resi's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=268138
should work in any version of ecuflash
Old Aug 10, 2008 | 06:43 PM
silver9mr's Avatar
yea we tried that but under misc he dident have the option of "ECU Periphery0"
Old Aug 10, 2008 | 06:53 PM
streetvision's Avatar
you can try TephraMod V5 or the newer V5.10 they both have 02 disable mod.
TephraMod V5--https://www.evolutionm.net/forums/sh...d.php?t=332778
TephraMod V5.10--https://www.evolutionm.net/forums/sh...d.php?t=362643
Old Aug 10, 2008 | 08:03 PM
Resi's Avatar
did you edit the correct xml file for your ecu rom id?
what is your rom id? post up your xml and ill see if i can get it working for you
Old Aug 10, 2008 | 08:20 PM
i didn't edit any files yet. rom id.. u lookin for the 8 digit number labeled under rom, then internal id?
Old Aug 10, 2008 | 08:58 PM
Resi's Avatar
yes, the internal id is your rom id.
You will have to add the code from the link i posted into the xml file for your rom id.
If ecu flash is open, close it, then reopen, and load your rom. The option will now be listed.
Old Aug 11, 2008 | 06:44 PM
when i try to edit the interal id it just asks about the x and y values n ish. i am generally smart with computers but this stuff makes my head spin. what do i need to edit and what number do i need to put where.
Old Aug 12, 2008 | 02:00 PM
silver9mr's Avatar
any luck with that yet ryan
Old Aug 12, 2008 | 04:16 PM
not really. justin may be able to figure it out unless somebody else on here replys with like a HOW TO for dummies on disableing the o2. mine was done by christian but it seemed so simple. i can't believe i can't figure it out
Old Aug 12, 2008 | 04:27 PM
silver9mr's Avatar
well than free bump for u lol rear o2 disable for dummies
Old Aug 14, 2008 | 03:14 PM
JohnBradley's Avatar
Originally Posted by JohnBradley
Disable the Rear O2 routine in the ROM
Update the ECUFlash XML file located at: C:\ProgramFiles\OpenECU\EcuFlash\rommetadata\mitsu bishi\evo\ (insert your current rom here).xml
Using Notepad or other XML editor to include the following entry so the code ends like this:
<table name="ECU Periphery0" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
</rom>
In other words it will be the last entry in the file and will have that close tag near it ( </rom> )
Open ECUFlash v1.3 and your ROM image. Scroll down to the Misc section and locate the "ECU Periphery0" entry. If the value for this entry is "0x56DA," press "=" on your keyboard and type "0x56D8" (without quotes) and press Enter. If the value for this entry is "0x56DB," press "=" on your keyboard and type "0x56D9" (without quotes) and press Enter.
Save the ROM image and flash your ECU with the new file. IF the value is anything other than whats listed do not modify it. I have a feeling this will work on the EDM as well, but I dont have an EDM ROM to look at to check.
JB
Here it is
Old Aug 14, 2008 | 09:40 PM
^ good info. i will try that in the am. thanks
Old Aug 18, 2008 | 08:46 PM
</rom>
JB
Under the MISC section, there is no selection in my ecuFlash that states ^ (ecu periphery0
