disable o2, Version 1.35.1650?????
Originally Posted by JohnBradley
Disable the Rear O2 routine in the ROM
Update the ECUFlash XML file located at: C:\ProgramFiles\OpenECU\EcuFlash\rommetadata\mitsu bishi\evo\ (insert your current rom here).xml
Using Notepad or other XML editor to include the following entry so the code ends like this:
<table name="ECU Periphery0" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
</rom>
In other words it will be the last entry in the file and will have that close tag near it ( </rom> )
Open ECUFlash v1.3 and your ROM image. Scroll down to the Misc section and locate the "ECU Periphery0" entry. If the value for this entry is "0x56DA," press "=" on your keyboard and type "0x56D8" (without quotes) and press Enter. If the value for this entry is "0x56DB," press "=" on your keyboard and type "0x56D9" (without quotes) and press Enter.
Save the ROM image and flash your ECU with the new file. IF the value is anything other than whats listed do not modify it. I have a feeling this will work on the EDM as well, but I dont have an EDM ROM to look at to check.
JB
Under the MISC section, there is no selection in my ecuFlash that states ^ (ecu periphery0
</rom>
JB
2. Did you edit your xml file and add the statement in bold?
in my other thread i am runnign into the same error message as i am here. i try to save the info on my xml file and it says check path and will not save.
n e ideas?
i posted an attachment in my other thread https://www.evolutionm.net/forums/sh...d.php?t=364229
n e ideas?
You are running Vista, that is the issue. I had this same issue when i began tuning. Basically the issue you are having is that Vista is 'protecting' the Program Files folder, which wont let you edit/save files or access certain files in the folder.
To fix the problem, I installed all my tuning stuff in C:\ECU Tuning\ECU Flash, C:\ECU Tuning\EVOScan, etc etc.
Being outside of the Program Files folder will prevent Vista from from protecting the files.
There is another way around this issue as well, but this was my solution.
I have a question.. I have a nut on my rear O2 to keep it happy, but recently it started giving me a CEL.. So i figured i'll just disable it with periphery bits.
My faa is 56DA, so i changed it to 56D8. CEL went away, but here's the problem — my LTFT's stopped registering... STFT feedback keeps on working, but LTFT's stay at 0. As soon as i reflashed 56DA back, the trims started working again.. And the CEL came back later in the day....
Has this happened to anyone else?
SmurfZilla
Oct 25, 2010 08:49 PM
