evoscan, can't open logs w/excel
I can log my pulls fine but then when i go to open it with excel it says error and won't open.
Does anybody else view their logs with excel? I have heard of other evo owners doing it this way however I can't find the files on my computer after I logged my pull. Using evoscan the logs can be opened but will not open with excel because they only seem to save in shortcut form.
help needed
help needed
Are you going to My Computer -> Hard drive -> Program Files -> EvoScan -> Saved Data Logs
If you are, your log files should show the Excel Icon, if not, Right Click on the File and go to "Open With" and select Excel.
Report back
-E
Report back
-E
If you open EvoScan and click on the "Logging" drop down menu, you should see an option labeled "Explorer - Open csv Log File Folder". This will open the folder where your logs are saved, it is usually something similar to "C:\Program Files\EvoScan\EvoScan v2.5\SavedDataLogs"
Here is a picture when I try to OPEN WITH EXCEL. I get this error message.
The same thing happens to me. Usually if I go to the folder thru explorer the logs wont show at all but when I run Evoscan they do. I have no idea why this happens. What worked for me was deleting the file and restoring it again and that seems to solve the problem.
That was happening to me on my new laptop, with windows Vista. When you click the open csv files, and that box opens. There should be a selection for compatability files. That should be where your logs are saving. That's where mine now go for some reason.
I had the same issue. It got annoying with hitting the compatibilty files. Download service pack 1 for vista. That cleared up all the car stuff issues i was having with vista
yup. thanks alot. i actually found that "compatablity files" section just before you posted the reply. thanks for the help.
Since this thread is already open maybe some of u can help me with something else also..
When i log my LoadCalc, the numbers are incorrect. The numbers vary from 2000-5000. What units is it logging and and how can u change it to read normal engine load?????
i will post the calc when i get home.
as far as the 2 byte load, The previous tuner i had set up my evoscan with 2byte load however i have since rebooted my whole comp and had to reload all of my software therefore loosing my 2byte load setting. A link to how to install 2byte would be apreciated.
thanks for all the help so far. hopefully i will be able to do all this on my own soon
Read this thread for setting up 2-byte load. You have an 03 so I figure the rom 0008 will be for you.
https://www.evolutionm.net/forums/sh...d.php?t=327185
Thanks, i will look into that thread in just a minute. To answer the previous post...
the LoadCalc forumula its curently using is 5*513*((0.256*x)-(-0.1026*[Battery]+1.8741))/[AFRMAP]
There is a Box i can select on evoScan that says LOAD MUT 2byte Mod. Should i select that instead of the LoadCalc selection or do i still need to follow the post above this one and set up the 2-byte load??
i found the ID that i have
94170008
2byte load
MUT 00 = 895C
MUT 01 = 895D
2byte RPM
MUT 02 = 893A
MUT 03 = 893B
2byte AirFlow
MUT 04 = 89BA
MUT 05 = 89BB
Now my question is how do I make the changes.
What do i have to do inorder to put those numbers (895C, D) on my ecuflash.... or do i put it on evoScan somehow??
