You and your load......
Old Aug 12, 2008 | 08:35 PM
Rob_GPT's Avatar
ok... it's off topic a little but I lol'd at the title... good stuff
Old Aug 13, 2008 | 12:50 AM
tephra's Avatar
stock turbo:
24psi peak = 260+ load @3200rpm
20psi taper = 220+load @ 7000rpm
98RON...
Old Aug 13, 2008 | 03:20 AM
vicbdn's Avatar
93 octane, mods in sig. Looking at all your numbers it seems mine is a little high for my boost level? Perhaps i have a leak?
Psi According to my prosport gauge...
22 psi peak = 250 load @ 3500 RPM
20 psi @ redline = 230 load
Could anyone explain the variances/dips in my load graph from 3500-5500 RPM?
Old Aug 13, 2008 | 02:40 PM
PeteyTurbo's Avatar
But a leaking BOV is not a boost leak, there is no metered air lost, therefore the mas will be seeing the same amount as it would be anyway. I am having difficulty understanding how this could give me a load calculation higher then without a leaking bov. Also I crushed the bov today and will be installing it tonight to see if it made a difference.
Originally Posted by Ted B
The problem with boost leaks is that indicated load gives a false high reading and kicks everything into the wrong fueling and ignition map cells.
Better fix it.
Old Aug 13, 2008 | 04:07 PM
Ted B's Avatar
My statement obviously best applies to a VTA setup, so apologies for the confusion.
As for a recirculating type, one would think that it shouldn't be an issue aside from the turbo losing efficiency due to the leak, unless of course the high pressure return stream has a means of disrupting the MAF.
Old Aug 13, 2008 | 04:38 PM
PeteyTurbo's Avatar
Now we are on the same page Thats why I said I know I was probably overspinning my turbo..I'm putting the crushed MR jdm bov back on now. We'll see if she holds past 25 now
I'm ALMOST tempted to get a tial but I wantto wait and see how their new recirculating valve works first..The only other big boost recirc. opion I can think of is the old school greddy type-r..
Old Aug 13, 2008 | 05:31 PM
Ted B's Avatar
I don't want this to go off topic, but I'd forget about the Greddy (won't explain here - but it did not perform to our standards), and consider a Synchronic or Forge RS.
Old Aug 13, 2008 | 06:28 PM
Smogrunner's Avatar
Mods in my signature.
23.8 psi of boost
100 octane
480whp/401wtq
11.3 sec at 123 mph
379.5 peak load
Old Aug 18, 2008 | 03:34 PM
Vigman's Avatar
320-330 on 93 octane @ 25PSI...
Old Aug 18, 2008 | 03:57 PM
PeteyTurbo's Avatar
geddy type R??
Old Aug 18, 2008 | 04:15 PM
G20's Avatar
G20
with 24 psi and I'm only hit 260 load cells but I'm only have mbc and tbe. So with something like AEM open intake and cams I should hit higher load cells (and tune of course). Correct?
I'll try to advance some timings to see if the load cells change to higher.
Old Aug 18, 2008 | 04:28 PM
cpoevo's Avatar
Cam timing or ignition timing? Advancing ignition timing will not change your load.
Old Aug 18, 2008 | 04:32 PM
psphinx81's Avatar
hta 35r, load values hit 340's
100 octane, 30 psi
Old Aug 18, 2008 | 04:33 PM
G20's Avatar
G20
ignition. Thanks.
Old Aug 18, 2008 | 04:56 PM
93 3gt vr4's Avatar
300-315 @ 25psish
