USDM EVOX map offsets
Old Aug 13, 2008 | 11:11 PM
EFIxMR's Avatar
Thumbs up USDM EVOX map offsets
http://forums.openecu.org/viewtopic.php?p=18669#18669
The guys over on the Openecu.org forum released the USDM EVOX ROM. Here's some definitions I found so far based upon what I learned with the EDM EVOX ROM.
hi ign 1 table offset 5590b
lo ign 1 table offset 55b0d
ign load offset 60f76 elements 22
ign rpm offset 616f4 elements 23
hi fuel table offset 5517f
lo fuel table offset 552d7
hi fuel 1 table offset 5542f
lo fuel 1 table offset 55027
fuel load offset 63cc6 elements 21
fuel rpm offset 63d1e elements 16
injector scaling table offset 556cc
injector scaling offset 6512e elements 7
boost cut table offset 555b4
boost cut scaling offset 651ca elements 9
Need to find to find the Mivec, WG duty, boost target, and boost maps still, but I gotta get off the computer now. If anything is defined wrong please feel free to correct me.
Old Aug 14, 2008 | 03:03 AM
dark-evo's Avatar
boost cut table offset 555b4 - it is not boost limiter
<map name="Intake cam1" type="3" active="1" help="" class="Mivec" map_struct="" level="0">
<rows scaling="Evo32_axis_Rpm16" count="24" offset="#0" inc_data_offset="#0"/>
<cols scaling="Evo32_axis_Load16" count="21" offset="#0" inc_data_offset="#0"/>
<data scaling="Evo32_data_VVT_Angle" count="1" offset="#5DB1D" order="rc" color_dir="1"/>
</map>
<map name="Intake cam" type="3" active="1" help="" class="Mivec" map_struct="" level="0">
<rows scaling="Evo32_axis_Rpm16" count="24" offset="#6104A"/>
<cols scaling="Evo32_axis_Load16" count="21" offset="#60E0E"/>
<data scaling="Evo32_data_VVT_Angle" count="1" offset="#5DD1D" order="rc" color_dir="1"/>
</map>
<map name="Exhaust cam1" type="3" active="1" help="" class="Mivec" map_struct="" level="0">
<rows scaling="Evo32_axis_Rpm16" count="24" offset="#0" inc_value="1"/>
<cols scaling="Evo32_axis_Load16" count="21" offset="#0" inc_value="1"/>
<data scaling="Evo32_data_VVT_Angle" count="1" offset="#5DF1D" order="rc" color_dir="1"/>
</map>
<map name="Exhaust cam" type="3" active="1" help="" class="Mivec" map_struct="" level="0">
<data scaling="Evo32_data_VVT_Angle" count="1" offset="#5E11D" order="rc" color_dir="1"/>
</map>
Boosted Tuning
Aug 26, 2023 10:14 PM
mrfred
Dec 15, 2022 11:13 AM
mrfred
Feb 26, 2022 06:16 PM
mrfred
Sep 17, 2017 06:11 AM
CammedEvo
23
Oct 6, 2010 09:45 PM
