Engine Load %
Old Aug 17, 2008 | 06:31 PM
SiC's Avatar
SiC
Engine Load %
Sorry for being such a newbie but I was wondering how engine load % is determined by the ECU. When ever I see a Fuel or IGN Timing map it's always RPM / Engine Load %. Is engine load determined by the MAP, MAF, & TPS readings? Or is it just simply the MAP??
Thanks in advance
Old Aug 17, 2008 | 06:57 PM
tephra's Avatar
Its essentially the amount of air going into the engine, so based upon the MAF.
Old Aug 17, 2008 | 10:42 PM
SiC's Avatar
SiC
Thanks, that is what I thought but I read some posts where people were referring to Engine Load % as MAP readings. ie: 260% Engine Load = 165kpa or 24 psi
I have a Greddy Informeter that hooks up to my OBD2 port and it shows MAF %. The values are from 0%-300%, is this the same as the Engine Load % the ECU maps are referring to? The highest numbers it reaches in 3rd gear is around 250% @7500RPM 18psi boost.
Old Aug 17, 2008 | 10:57 PM
tephra's Avatar
mmmm not really...
You can "correlate" the PSI from the MAF, but its not an exact science.
If you want to know what load cells your car is hitting you need to log 2byte load.
Not sure what progress has been made on the X yet in this regard...
jars121
Mar 12, 2017 08:10 PM
Nightbreeze
Dec 8, 2015 11:49 AM
ptm5070
Dec 18, 2014 09:06 AM
bigric09
Sep 4, 2007 09:59 AM
Noogles
Jun 16, 2006 10:24 AM
