First Logs with WB (weird knock up top)
Old Aug 27, 2008 | 08:53 AM
  #31
Turbo Kyle's Avatar
Going to make a boost leak tester today so I dont have to use my friends anymore.
Old Aug 27, 2008 | 01:40 PM
  #32
Turbo Kyle's Avatar
Boost Leak tested...34 psi no leaks.
Old Aug 27, 2008 | 01:49 PM
  #33
Mellon Racing's Avatar
hmmm...sounds like it's time to get that AFR right and shave off the excess timing or see about a big fmic and other mods that could raise the knock threshold a bit. Have you tried a colder plug yet?
Old Aug 27, 2008 | 02:10 PM
  #34
Turbo Kyle's Avatar
I just put a new set of stock plugs in the car...think they are too hot?
I think I could have a bug in the Tephra patch...The car is buckin/shutting off at 60% throttle when Im at 1800-2200 rpms and 5 psi of boost. Its not the BOV either. Here is that thread > https://www.evolutionm.net/forums/sh...d.php?t=366038
I when I was doing my leak test I went ahead and unplugged the + batt cable. Weird thing is Im not seeing any knock (I have the CEL flash knock mod). I need to do another log with it. I also noticed that my MIVEC map up top could possibly uses some tweaking.
Old Aug 27, 2008 | 02:21 PM
  #35
awdboosted's Avatar
I personal think you're running too much timing.. I've not been able to get away with that much on 93 with 25 psi. at most I've gotten 8 degrees.
Old Aug 27, 2008 | 02:22 PM
  #36
h101171's Avatar
my suggestion to your Mivec:
Set the values in the area 6000/160load to 7000rpm/300load to zero.
Old Aug 27, 2008 | 02:32 PM
  #37
awdboosted's Avatar
If you can find a part number for a colder copper plug on the IX let me know. I've been looking.
Old Aug 27, 2008 | 03:45 PM
  #38
order it from buschur
Old Aug 27, 2008 | 04:38 PM
  #39
lemmonhead's Avatar
in your MIVEC change all those 14.4 to 19.8
your 6000RPM row change to 14.4
7000RPM row change to 9.8 or lower.
and dont change anything else. see if the knocks go down.
Old Aug 27, 2008 | 04:48 PM
  #40
awdboosted's Avatar
No one has a part #??
Old Aug 27, 2008 | 08:07 PM
  #41
Turbo Kyle's Avatar
Thanks bro...where are you in MO?
Old Aug 27, 2008 | 08:09 PM
  #42
Turbo Kyle's Avatar
Thanks...I will update tomorrow with some test results. Whats better, lower boost more timming? or more boost less timming?
Old Aug 27, 2008 | 08:45 PM
  #43
RazorLab's Avatar
Remember 30 in the mivec table does nothing. 28.8 is the max
There is currently no copper plug for the 9.
One step colder iridium is Denso IKH24
Old Aug 27, 2008 | 10:10 PM
  #44
Turbo Kyle's Avatar
You think the Plugs could be the problem?
Old Aug 28, 2008 | 12:56 AM
  #45
RazorLab's Avatar
Sorry the plug info was for awdboosted
